Activity Forums VEGAS Pro Vegas Pro 8 sound editing
  • Vegas Pro 8 sound editing
    Posted by Jesse Davenport on August 30, 2010 at 10:57 am
    Okay, so I’m working on a project and there’s this sound effect I really like, but it’s more dominant on the left speaker than the right, is there a way to make it play out of both speakers?
    Mike Kujbida replied 16 years ago 3 Members · 7 Replies
  • 7 Replies
  • John Rofrano
    August 30, 2010 at 1:24 pm
    You can isolate the sound on it’s own track and use the Pan control to move it back into the center or you can insert a Pan Envelope on the track that it’s on and add keyframes to pan just that event back into the center.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Mike Kujbida
    August 30, 2010 at 9:05 pm
    Make it a mono event instead of stereo.
    Right-click – Channels – Combine.
  • John Rofrano
    August 30, 2010 at 9:09 pm
    That’s a good idea too but combining them may cause phase cancellations. You could make it mono by just using the louder of the two channels if both have the same information just one louder than the other.
    ~jr
  • Jesse Davenport
    August 31, 2010 at 10:24 am
    I’ve tried moving it to the center ant the left side is still more dominant. When I move it all the way to the right it sounds muffled, like there is no sound coming from the right side.
  • Mike Kujbida
    August 31, 2010 at 10:34 am
    In that case, Right-click – Channels – Left Only.
    It’s now a mono signal coming out of both channels at the same level.
  • Jesse Davenport
    August 31, 2010 at 10:35 am
    That did it, thank you so much!
  • Mike Kujbida
    August 31, 2010 at 10:56 am
    I’m still curious as to why the original sound file was messed up but at least it finally worked out for you.
