Activity Forums VEGAS Pro Vegas Pro 8 Project Inspector Custom Command
  • Vegas Pro 8 Project Inspector Custom Command
    Posted by Edward Troxel on September 14, 2007 at 3:32 pm
    Download Project Inspector here
    Project Inspector is a new Vegas Pro 8 Custom Command that will search for several of the common mistakes made during editing. It opens as a window that can be docked with any of the other Vegas windows. It can be set to automatically check for errors or only do manual checks. It will be turned off until the Project Inspector window is opened.
    To access the Project Inspector, go to View – Extensions – Project Inspector. It will dock in the docking area and can be undocked and resized as desired. Click on Preferences to set your desired options. As you work, it will update automatically (or you can click the “Update Now” button) and show the following “possible problems”:
    1. Track Opacity slightly above 0% or below 100%
    2. Event Opacity slightly above 0% or below 100%
    3. Track Audio levels slightly above or below 0db or slightly above “off”
    4. Event Audio levels slightly above or below 0db or slightly above “off”
    5. Track Audio pans slightly left/right of center
    6. Small video or audio events
    7. Playback rates slightly above or below 100%
    8. Short Fade-in/Fade-out for audio and video events (with option to ignore “quickfades”)
    9. Indicates if a video event is NOT on a frame boundry
    10. Indicates if media is “Off-line”
    The Project Inspector screen is automatically (unless that option is turned off) or manually updated. For every issue on the screen, you can double-click on the timecode and the cursor will be moved to the location of that issue. With the proper option set, you can also single-click on the issue description to be taken to the location of that issue.
    If you double-click the issue, the Project Inspector will attempt to “fix” most issues. If you don’t like the “fix”, simply UNDO and apply your own fix.
    More issues and fixes may be added in the future. Feel free to e-mail requests.
    Edward Troxel
    JETDV Scripts
    http://www.jetdv.com
    Edward Troxel
    JETDV Scripts
    Vincent Croce replied 19 years ago 7 Members · 6 Replies
  • Seth Estrada
    September 14, 2007 at 7:43 pm
    Thank you very much. This tool will save many people many headaches.
    “Oh be wise, what can I say more?”
  • Rick Mac
    September 15, 2007 at 2:14 am
    Very slick tool Edward.
    Later…Rick.
    I feel a friendly round coming on.
  • Graham Bernard
    September 16, 2007 at 6:57 am
    Love it – L o v e I-T!!
    So simple, even I can use it.
    Thanks Edward!
    Grazie
  • Mahesh Upadhyaya
    September 16, 2007 at 8:14 am
    It is very genorous of you, Edward, to put such a powerful tool in public domain.With your auto save command, it fixes the chinks which always existed in Vegas armoury.
    Thank you.
    Regards
    Mahesh
    https://www.crestvideo.co.uk
  • Kevin Mccarthy
    September 16, 2007 at 4:19 pm
    Ed
    You never cease to amaze me!!! Great stuff!
    Kevin McCarthy
  • Vincent Croce
    September 16, 2007 at 6:19 pm
    Thanks so much, Ed, not only for this Project Inspector tool you’ve generously given to the Vegas community, but for the time, energy, and expertise you’ve shared with myself and others over the years via the Cow, DVI and other forums, and your excellent website, JetDV.
    You Da Man!
    Vin Croce
