VEGAS Pro 23 – Nested Compound Clips + Optical Flow Causing Audio/Video Sync Iss
Hi everyone,<div>
</div><div>I’m working on a project in VEGAS Pro 23 where I’m using a mixture of 29.97 and 59.94 FPS footage. My project is set to 29.97 FPS.</div><div>
</div><div>I have a few clips that I’ve slowed down using Optical Flow, and those clips are inside nested/compound sequences because I have some additional effects and masking applied to them.</div><div>
</div><div>The problem is that after nesting the clips, the slowed-down sections occasionally become slightly out of sync with the audio. The preview looks correct initially, but after rendering or reopening the project, the video seems to drift by a few frames</div>
