Activity › Forums › VEGAS Pro › Vegas Pro 22 audio exports
  • Vegas Pro 22 audio exports
    Posted by Pete Tombs on June 8, 2026 at 10:25 am
    I’ve edited some audio files to match a feature. I want to do clean up on the files so exported them as .wav, intending to do some work on them with Audacity etc. When I import them back into the Vegas project I discover that the exported file seems to have been stretched slightly so is now out of sync with the original file (slightly longer). This before I have done anything with the exported file.
    Silviu Negoita
    replied 2 months ago
    2 Members · 1 Reply
  • Silviu Negoita
    July 20, 2026 at 1:48 pm
    Hello! It seems to me that the problem might be occuring due to a “failed” sample rate. Please check if your project sample rate is set to 48.000 HZ (File – Properties – Audio), afterwards, check if the WAV file is being exported at the same sample rate (It should be somewhere in files properties)
    If the problem still occurs after checking this please tell me your vegas build number.
