Vegas Pro 17 is here…..
Posted by Steve Rhoden on August 5, 2019 at 7:54 amhttps://www.vegascreativesoftware.com/gb/vegas-pro/
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
https://www.facebook.com/FilmexCreativeMediaJeff Lee replied 7 years ago 5 Members · 8 Replies -
Wilfried Van
August 7, 2019 at 6:30 amIt is here yes…. and doesn’t work with many plug-ins anymore such as boris continuum complete and others ….
Still on the latest SONY vegas pro 13 which is the most stable here , together with vegas pro 7 which NEVER has crashed on any system 🙂 -
John Bolton
August 7, 2019 at 7:47 amYes…. BCC 8 plug-in no longer working and a few other things .
So my Match Move is no longer .Bezier Masking seems to be not as good compared to V16 using the same bit of media.
I notice on the Magix site something called “Planar Motion Tracking” .. Was that just a rename marketing” Bezier” or an I looking in the wrong place at the moment.?
☹ NewBlue still works…
Wilfried Van
August 7, 2019 at 8:57 amBCC12 also not working anymore and preventing vegas pro 17 trial to start.
Well , anyway , let’s just see what happens in the next update , there is a lot of beta testers in the magix vegas forum 😉 -
John Bolton
August 7, 2019 at 9:58 amI had to uninstall BCC, then load V17 Trial..
That got V17 working, then I re-installed BCC V8 Plugs and V16 lists it and works OK but of course V17 does not find it.
Linda O’connell
August 11, 2019 at 1:45 pmTotally agree with you. I have 16 and 12 and only use 16 for specific movie files (they are mov files imported from old 8mm film. They don’t work on 12) Every other time I have tried 16 even for a simple slideshow, it crashes or doesn’t render. (I have 2 different brands of computers/systems..both crash)
Never had an issue, ever with 12. -
Jeff Lee
August 11, 2019 at 2:27 pmYes, there are issue but Magix has been very responsible in getting things fixed. So far the color grading and the new lens correction filter have been the stars for me. I have the 7.5 FE, Oly 9-18, and use the Pany 14mm f2.5 with GWC1 for a low light 10mm, this filter makes its extremely easy to get to video. Secondly with the right settings I am now getting 1:1 render on my old i7700/4200 ghz 32 gig memory and RX480 8 gig with the HEVC codecs. A little faster on the 16 on the Magix PRO Res settings. I always leave the previous version on for a couple of months. Lots of good things in Vegas since Magix took over. When Acid became comatose in Sony’s hands I switched to Samplitude & kept Sound Forge and now with Vegas my little (and I do mean little) production studio does more than I will ever need. Been using my G9 to shoot 6K video and it’s nice to be able to use Vegas and proxies to use the 6K to crop in a 4K timeline. If you are not in the Magix forum (a bit of the wild, wild west at times) and your a VP user, you should visit.
Linda O’connell
August 11, 2019 at 10:39 pmYour uses are totally different than mine. 95% of the footage I transfer isn’t even in HD (or widescreen) let alone 6K. (VHS tapes, Hi 8 tapes and Hi tech DV tapes) Ha ha. That being said what is the difference between the Magix forum and the Pro?
Jeff Lee
August 12, 2019 at 1:59 pmOne and the same I think:
https://www.vegascreativesoftware.info/us/vegas-pro-forum/
