Activity › Forums › VEGAS Pro › Vegas Pro 15 Project Markers in DVD Architect
  • Vegas Pro 15 Project Markers in DVD Architect
    Posted by Rob Bond on December 18, 2018 at 12:22 am
    I am having trouble getting the Vegas Pro 15 project markers to show up in DVD Architect (Build 67, 2016). “Save Project markers in render Media File” option is set when render the Digital Dolby AC3 audio from Vegas. The video is being rendered as “Magix AVC/AAC MP4 (Blu-Ray 1920×1080, 60i 25 Mbps video stream)”.
    My understand was Project markers are saved in the *.sfl file (which is located in the media folder along with the DVDA project file)
    Any suggestions?
    John Rofrano replied 7 years, 9 months ago 2 Members · 3 Replies
  • John Rofrano
    December 18, 2018 at 12:22 pm
    [Rob Bond] “My understand was Project markers are saved in the *.sfl file (which is located in the media folder along with the DVDA project file)”
    That’s correct. Is that file being created? It must be in the same folder as the file it is the markers for. So if you have my-video.ac3 then my-video.ac3.sfl must be in the same folder along side it for DVD Architect to know that’s the markers for that file and it must have the same name including extensions as the file but with the added .sfl extension.
    Have you tried loading it manually? There is an option in DVD Architect to load the markers file.
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
  • Rob Bond
    December 18, 2018 at 8:11 pm
    Using the Vegas Pro 15 Sony AVC/MVC Blu-ray template fixed the problem. I am not sure why the Magix AVC Blu-ray template appears to lacks the ability to embed Marker information, but now that I know I will avoid it when authoring to Blu-ray.
    As a point of reference, the Magix AVC Blu-ray render template lacks the “Save Project markers in render Media File” option, while the Sony AVC/MVC Blu-ray template has this option.
    –Rob
  • John Rofrano
    December 19, 2018 at 1:43 pm
    [Rob Bond] “Using the Vegas Pro 15 Sony AVC/MVC Blu-ray template fixed the problem. I am not sure why the Magix AVC Blu-ray template appears to lacks the ability to embed Marker information, but now that I know I will avoid it when authoring to Blu-ray.”
    That’s good to know. Thanks for reporting back here so that others can benefit from the knowledge in the future.
    ~jr
