Activity › Forums › VEGAS Pro › Vegas Pro 15 frame rate anomaly
  • Vegas Pro 15 frame rate anomaly
    Posted by Pete Tombs on August 22, 2018 at 6:41 pm
    I am trying to edit a Pro Res 422HQ file that runs at 24fps. I load it into the Vegas 15 timeline. Then when I try to move forward one frame at a time using the keyboard right arrow, although the frame counter says I am moving one frame, the video does not move. In fact it takes four frame forwards to move one frame of video in the preview window. If I render a section of the video it plays in jerky slow motion. I have checked and there is nothing selected in the preferences etc that would make it run in slow motion. Velocity is set at 100% , Playback rate set at 1.000 in preferences. The file plays fine in other programs and will shuffle forward and backwards one frame at a time with no problem in other edit packages, including older versions of Vegas.
    George Dean replied 8 years, 1 month ago 4 Members · 20 Replies
  • 20 Replies
  • Ole Kristiansen
    August 22, 2018 at 6:50 pm
    Hi Pete !
    What is the spec of you computer ?
  • George Dean
    August 22, 2018 at 7:34 pm
    Pete, you have probably checked this, but are your project properties set to match your source media?
    Best Regards……George
  • Pete Tombs
    August 22, 2018 at 8:03 pm
    Yes they are. When I imported the media I accepted the “set project properties to match media” option.
    And I rechecked that it was so afterwards.
  • Pete Tombs
    August 22, 2018 at 8:13 pm
    Windows 7 64 bit
    Intel Xenon R CPU W3505 @2.35 ghz
    12 gig Ram
  • Pete Tombs
    August 22, 2018 at 8:20 pm
    and it’s one particular video stream that’s exhibiting this weird lag. The bit of video in the other video track responds fine. But that’s DNxHD. Maybe I should convert the other video to DNxHD too?
  • George Dean
    August 22, 2018 at 8:45 pm
    Pete, is there anything weird in the source media specs? Does Mediainfo (text mode) reveal anything out of the ordinary? What kind of camera codec was used to record the ProRes?
  • Pete Tombs
    August 22, 2018 at 9:08 pm
    all looks very standard to me. It was a scan from a 35mm print. 4k, downconverted to HD.
    It plays fine in other players (like VLC) where I can move it forward frame by frame with no issues and it plays fine in Resolve etc. But I have a very complicated projec t in Veags that I’m loathe to recreate in Resolve so I’d really like to get it working in veags. I think this must be a Vegas problem. I’ve had no response as yet from their customer service helpline
    General
    Folder: E:
    Type: MAGIX ProRes
    Size: 37.56 GB (38,462,056,770 bytes)
    Created: 16 August 2018, 12:23:42
    Modified: 16 August 2018, 12:41:46
    Accessed: 16 August 2018, 17:13:12
    Attributes:
    Streams
    Video: 00:25:34.333, 24.000 fps progressive, 1920x1080x32, ProRes
    Audio: 00:25:34.333, 48,000 Hz, Stereo, PCM
    ACID information
    ACID chunk: no
    Stretch chunk: no
    Stretch list: no
    Stretch info2: no
    Beat markers: no
    Detected beats: no
    Other metadata
    Regions/markers: no
    Command markers: no
    Media manager
    Media tags: no
    Plug-In
    Folder: C:\Program Files\VEGAS\VEGAS Pro 15.0\FileIO Plug-Ins\mxhevcplug
    Format: MAGIX ProRes
    Version: Version 1.0 (Build 8532)
    Company: MAGIX Computer Products Intl. Co.
  • Pete Tombs
    August 22, 2018 at 9:13 pm
    and here’s the mediainfo text:
    General
    Complete name : E:\Wild_Pussycat_Restored.mov
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt 0000.00 (qt )
    File size : 35.8 GiB
    Duration : 25 min 34 s
    Overall bit rate : 201 Mb/s
    Encoded date : UTC 2018-08-16 11:23:42
    Tagged date : UTC 2018-08-16 11:41:46
    Writing library : Apple QuickTime
    Video
    Format : ProRes
    Format version : Version 0
    Format profile : 422 HQ
    Codec ID : apch
    Bit rate mode : Constant
    Bit rate : 198 Mb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 24.000 FPS
    Color space : YUV
    Chroma subsampling : 4:2:2
    Scan type : Progressive
    Bits/(Pixel*Frame) : 3.982
    Stream size : 35.4 GiB (99%)
    Title : Core Media Video
    Writing library : adv0
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio #1
    Format : PCM
    Format settings : Little / Signed
    Codec ID : lpcm
    Bit rate : 1 152 kb/s
    Channel(s) : 1 channel
    Sampling rate : 48.0 kHz
    Bit depth : 24 bits
    Stream size : 211 MiB (1%)
    Title : Core Media Audio
    Audio #2
    Format : PCM
    Codec ID : lpcm
    Bit depth : 24 bits
    Other
    Type : Time code
    Format : QuickTime TC
    Time code of first frame : 01:00:00:00
    Time code, striped : Yes
    Title : Core Media Time Code / master
  • Pete Tombs
    August 22, 2018 at 9:30 pm
    I suspect it might be the mxhevcplug.dll plug in.
    I believe there are ways of bypassing it, but I’m sure that adds other complexities to the process.
    P
  • George Dean
    August 22, 2018 at 9:50 pm
    Hi Pete,
    I agree, nothing jumps out of the Mediainfo to imply there is something unusual about the source. And, the fact that it is fine in Resolve, I would tend to think it is Vegas having a problem.
    Have you tried to start a fresh project in Vegas and add only this clip to see how it reacts? There may also be something in the cached application data that is confusing Vegas. Maybe a Full Reset would help. Keeping in mind a reset and deleting the cached application data will return Vegas to it’s original installation configuration.
    It’s seem pretty weird, wish there was something I could put my finger on.
