Activity Forums VEGAS Pro vegas pro 14 – project properties not saved properly when restart
  • vegas pro 14 – project properties not saved properly when restart
    Posted by Wilfried Van on July 17, 2017 at 9:52 am
    Vegas Pro 14 has added disable resample in project properties , which is excellent but now it does not save and remember the ” view transform ” setting.
    Everytime I do restart vegas , I do have to go into project properties and change the view transform to ” OFF ” since that is always restarted as ” ACES “.
    My project properties are to be 32 bit floating point ( full range ) and view transform OFF . ( since vegas pro … long time ).
    Of course I am aware that after correct setting all settings , I have to save and apply these settings when starting.
    This is a simple but VERY annoying issue introduced in vegas pro 14 ( 270 )
    ( am working on very powerfull HP Z820’s systems solely used for editing and nothing else )
    Wilfried Van replied 9 years, 2 months ago 2 Members · 4 Replies
  • Graham Bernard
    July 17, 2017 at 12:55 pm
    [Wilfried Van] “My project properties are to be 32 bit floating point ( full range ) and view transform OFF .”
    Are you saying this is for existing projects, or new projects? Had you used the “Start all new projects with these settings” – I just did with your settings and a new projects holds your settings.
    Maybe I’m missing something?
    * Grazie
  • Wilfried Van
    July 17, 2017 at 2:53 pm
    Hi Graham ,
    Open vegas ( without a project ) for first time and set project properties properly , save and of course “Start all new projects with these settings” . ( am using vegas since version 4 and this basics I do know in meanwhile ☺ ) .
    Now close vegas .
    Re-open Vegas and everything BUT ” view transform ” is correct in project properties ( ie the OFF changed into ACES ).
    Wilfried
  • Graham Bernard
    July 17, 2017 at 3:03 pm
    Beat yah! I started with VV3 . . .
    Sorry, I can’t repro your issue.
    * Grazie
  • Wilfried Van
    July 17, 2017 at 4:09 pm
    Maybe I am not clear enough ☺
    Start vegas , do not load anything , just set the properties and set the ” apply these for all new projects ” and press apply.
    Now exit vegas .
    Restart vegas and verify the project properties -> all are correct but view transform ( ACES instead of OFF ).
    When saving a veg file with the properties , it reloads fine with all the project properties correct but each time vegas is started again and nothing yet loaded ( no veg file , vegas just opens ) the properties are again view transform to ACES instead of OFF .
    Bizar
