Activity › Forums › VEGAS Pro › VEGAS PRO 14: Problem with variable frame rate
  • VEGAS PRO 14: Problem with variable frame rate
    Posted by Yeray Rodríguez on January 26, 2020 at 10:40 pm
    Hello there,
    I´m a teacher, not very expert in creating videos. This year I decided to recor videos with students´ movile phones and that way could spend money in external microphones. Now I have an issue with the frames and thats why I write here. Im quite desperate. Need help.
    I am doing a video with diferent clips recorded with movile phones. Movile phones have variable frame rate.
    I create a project with 29,97fps, and even the videos recorded with the movile phones have vfr (some videos have 30,05 fps average, others 30… ), there is no problem when I render it. I render it with mainconcept avc codec and there is no problem.
    But I read that I shouldn´t do that, that i should convert all the videos to constant frame rate with handbrake. Could anyone help me?
    Im a a teacher and I create short films with my students. I would like to do it in the simplest way.
    Thanks in advance
    YERAY
    Graham Bernard replied 6 years, 7 months ago 2 Members · 5 Replies
  • Graham Bernard
    January 27, 2020 at 5:10 am
    [Yeray Rodríguez] “But I read that I shouldn´t do that, that i should convert all the videos to constant frame rate with handbrake. Could anyone help me? “
    Hi Yeray! What is your question? Is it how to use HandBrake or “why” should you be doing it anyway?
    * Grazie
    PC 10 64-bit 64gb * Intel® Core™i9 – 3.3GHz * 40Gb NVIDIA GeForce RTX 2070
    Cameras: Canon XF300 + PowerShot SX60HS Bridge
  • Yeray Rodríguez
    January 27, 2020 at 8:50 am
    My questions are:
    1. What would happen if I render the clips the way they are (vfr and @30fps)? A lot of videos have been already recorded
    2. If I use some clips with cfr, but some of them 25fps, some 30 fps, and I render everything with avc mainconcept 25fps. Would I have any problem?
    3. I have an option to record the videos with filmic pro and cfr=30fps. But that’s not 29.97fps. Would it be a problem? Because then, It’s suppose to be rendered in 29.97fps
    4. Is there any FREE app for android and ios that records video in cfr?
    5. Handbrake: I guess the only thing I should do is choose output with cfr and the fps I
    would like
    with no other change. Am I ok?
    Please note that We are doing short films, with conversations and so…
    Too many questions?
    Thanks in advance!
  • Graham Bernard
    January 27, 2020 at 9:57 am
    [Yeray Rodríguez] “Too many questions?”
    Nope. But maybe there COULD be too many answers! I’ll try and keep it simple and apply my own anecdotal experience. It’s tricky.
    I recently came back from Amsterdam, having shoot both 29.xx and 59.xx. I wanted the cadence from 59.xx and to apply slomo. So far so good. OK, once at the VP Timeline I got myself into a real pickle and decided to hit a majority of the 29 with a 59 render. Under my circumstances I also made sure I had deselected Resampling.
    This combo of Framerates and then VFR can be a real nightmare, especially once you get started with FX-ing or Speed Ramps, the wheels start falling off. My advice, is to experiment with your local footage. Keep in minded the final delivery formats too, oh yes….
    I apologise if my answers appear too flimsy, but it’s the best I can do. Others may have a better direct Route1 to this.
    * Grazie
  • Yeray Rodríguez
    January 27, 2020 at 9:52 pm
    Hey Graham,
    Many thanks for your answer. In your case, 59.XX is the double os 29.XX so… maybe you didn´t have as much problem as me.
    Anyway… what does “resampling” option do?
    Thank you
  • Graham Bernard
    January 28, 2020 at 3:56 am
    [Yeray Rodríguez] “Anyway… what does “resampling” option do?”
    Here’s one of many conversations on the matter :
    https://forums.creativecow.net/docs/forums/post.php?forumid=24&postid=995110&univpostid=995110&pview=t
    Granted, as the Framerates were multiples of the other, but yes, I did have a problem once getting into colour grading and temporal-dependant Noise Reduction and MOCHA Pro. But yours are more severe. Do a search on the matter and you’ll garner much hard won experiences.
    Good luck!
    * Grazie
