Activity Forums VEGAS Pro [Vegas Pro 14] Need to re-create the audio sounds of a pilot and PA Announcer.
  • Francois Pénzes
    June 5, 2021 at 5:05 am
    Hi Seth
    Try the Equalizer effect in the Freeware Dark Audacity, for the pilot effect, start by cutting all the frequencies below 200 Hz and the ones above 3000 Hz. From there, adjust to your liking.
    For the airport announcement, use the reverb effect as illustrated and adjust to your liking.
    Cheers!
  • Richard Swain
    June 5, 2021 at 11:20 am
    Hi Seth,
    I agree with Francolis, an equalizer is your best bet. However, I’m sure you have your reasons to make them sound “alike”, my observation to you is that the environment of the two tracks is completely different – female vs male, tiny room (on board the aircraft) vs a huge room at the airport, two different voice accents, etc. If, when you recorded these announcements, you also recorded some background ambiance sounds, what I would do is record your own announcements on top of the existing background.
  • Bruce Brent
    June 5, 2021 at 1:58 pm
    Seth, two simple ways. 1) Download the links you provided and put them on your timeline, removing only the video portion, leaving the sound track. 2) Use Audacity to record the links you provided and record “what you hear.” Go to the Audacity website to the tutorial on how easy this scenario is to accomplish.
  • Francois Pénzes
    June 5, 2021 at 5:40 pm
    You can get a bunch of different BG sound and noise at: https://freesound.org/search/?q=static.
    Be carefull not to make your BG to loud. It’s a common mistake.
    Cheers !
