vegas pro 14 having color issues at the beginning
Posted by Yasin Ulu on November 26, 2016 at 12:13 pmim just having weird color problems every beginning of the cuts. it happens few seconds then i see no problem.
i dont have any problem like that on vegas pro 13(happens beginning of the cuts.)
please check the images for better detailOle Kristiansen replied 9 years, 10 months ago 3 Members · 9 Replies -
László Kovács
November 26, 2016 at 1:32 pmHi,
I don’t see the problem. Can you post an image, where everything is fine?
Best regards
László Kovács
Yasin Ulu
November 26, 2016 at 2:38 pm -
Ole Kristiansen
November 26, 2016 at 3:14 pmDid you disable resample – and use constant bit rate – when you render ?
Yasin Ulu
November 26, 2016 at 3:34 pmsir when i disable resample it doesnt do anything , still having same problem .
for other things you said i didnt understand can you explain more detailed?also when i render video its still the same like in the preview . having same issues on rendered video too, thats how it looks like 🙂
Ole Kristiansen
November 26, 2016 at 4:28 pm -
Yasin Ulu
November 26, 2016 at 4:29 pmbut this is rendering step isnt it?
how can i fix that problem when im previewing the video?
the settings you said i wasnt using it like that , however i rendered the video with the settings you show me
it takes too long to render , also problem still continues 🙂
Ole Kristiansen
November 27, 2016 at 8:05 amYes, the constant bit rate is for rendering !
Do you have the mediainfo of your footage and a image of your project settings in Vegas ?
