Activity Forums VEGAS Pro Vegas Pro 14.0 Random “Blips” in Audio
  • Vegas Pro 14.0 Random “Blips” in Audio
    Posted by Isaac Beals on January 7, 2022 at 11:39 am
    Hey everybody!
    A bit of background: I decided to try my hand at ripping and editing a Bluray for fun, and eventually got a video file that was compatible with Vegas Pro (14.0). However, the audio tracks would spontaneously create “blips” (AKA strange popping noises) and it basically ruined the entire thing. Restarting the program sometimes fixed individual blips, but then new ones would pop up as I kept editing.
    I tried resetting everything in Vegas to the default settings, but that didn’t work. Then I tried a couple of different audio formats, but they all did the same thing.
    So, I would like to know if the problem is with my file or with Vegas and what I can do to fix it. (Also, I remember this sort of thing happening before with Vegas, but it was with smaller files and projects, so I could usually work around the glitches.)
    Here are the specs for the audio that I’m currently editing (within an M4V file, which was copied from the original Bluray MKV file with ffmpeg):
    Format : AAC LC
    Format/Info : Advanced Audio Codec Low Complexity
    Codec ID : mp4a-40-2
    Duration : 1 h 49 min
    Bit rate mode : Constant
    Bit rate : 128 kb/s
    Channel(s) : 2 channels
    Channel layout : L R
    Sampling rate : 48.0 kHz
    Frame rate : 46.875 FPS (1024 SPF)
    Compression mode : Lossy
    Stream size : 101 MiB (0%)
    Language : English
    Default : Yes
    Alternate group : 1
    Menus : 3
    Here are my PC specs:
    Windows 10 Home
    Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz 3.41 GHz
    16.0 GB RAM
    Isaac Beals replied 4 years, 7 months ago 2 Members · 2 Replies
  • Rich Kutnick
    January 7, 2022 at 4:11 pm
    Was this, by chance, a commercial Blu-ray? If so, my educated guess is that the blips are due to the copyright protection on the disk.
  • Isaac Beals
    January 7, 2022 at 9:50 pm
    Would copyright protection create blips at random? Also, if I ripped the file from the disc, would it still be copyright protected?
    If I just export the whole thing without editing it, there aren’t any blips. It’s just when I start editing it that the blips appear.
    Also, this has happened to me with non-Bluray files, just with less frequency.
