Vegas Pro 13 Visual C++ runtime error?
Posted by William Diels on December 10, 2015 at 12:41 amHey guys,
Over the last two weeks or so I have been experiencing some problems while editing my GoPro-footage in Sony Vegas 13. For some reason, this error (concerning Visual C++ runtime library) keeps popping up:
https://s23.postimg.org/j5p5hoc17/error.jpg
I have already tried to reinstall Vegas, but that does not make a difference.
Any clues on what to do? I can’t work on any edits, because the program keeps shutting down.
WilliamSteve Roberts replied 10 years, 7 months ago 4 Members · 8 Replies -
Mark Barton
December 10, 2015 at 3:44 amThat is an error from the Go Pro Studio software. Try updating it or reinstalling. It is the one that installs that Cineform dll.
Mark Barton
December 10, 2015 at 6:10 amI just happened to get the same error after my last post. I just dragged onto the timeline about a dozen clips that I had rendered using cineform. Not sure if it was the Windows update I applied just before or just the way I brought those clips to the timeline. I will share if I find out more tonight.
Mark Barton
December 10, 2015 at 5:53 pmUpdate. I chose ignore a few times and the clips ended up on the timeline and other than that assertion message, it appears it worked fine. I tried a new project and dragged one clip and then two clips, etc to the timeline to see if it was the number of clips at one time that caused the error. I did not get an error with that test. I have not noticed any issues yet once they are on the timeline with editing them and playback.
William Diels
December 11, 2015 at 4:51 amHey Mark,
Thanks for your replies. I will try reinstalling the GoPro software. I just discovered that the error only occurs with the AVI-files converted with GoPro studio. I have some problems with editing my GoPro footage in Vegas (but I asked that question in this topic: https://forums.creativecow.net/thread/24/995264)
I will see if I get any responses in the other topic and otherwise I will try and work around the assertion error.
Steve Rhoden
December 11, 2015 at 2:13 pmDid you uninstall this with any luck with no errors?
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
https://www.facebook.com/FilmexCreativeMedia -
William Diels
December 12, 2015 at 4:59 amI am about to reinstall GoPro Studio.
Should I also re-render the original files to avi with GoPro studio?
Mark Barton
December 12, 2015 at 6:05 pmThe assertion error looks to be file I/O related, so I tried changing the Sony Vegas Pro Option/Preferences/General and unchecked “Close media files when not the active application”. I restarted Sony Vegas after making that change and completed working on my project without getting that error again. See if that makes a difference for you too.
Steve Roberts
February 9, 2016 at 3:32 amI had been dealing with this issue since I reinstalled my machine just before Xmas.
What I had done is install the last free Cineform codec that is available from the cineform web site. I do have a Studio Premium license of Cineform. The reason I did this was the activation part of the cineform web site was not functioning. It returned a web based error once I entered all my details. So I forged on to attempt to fix this.
Well I never fixed it. I tried the Vegas preference suggested by Mark but no luck. I tried recreating the avi cineform files that appeared to be causing the problem inside Vegas but no luck.
What did fix it was the web site activation is working again. I got a new code for Studio Premium for the hardware change and all is fine again.
Sorry its not a fix but it might at least give some insight. Why the Free version should have issues and the Premium not ?
Steve
Amongst Projects
——— Sound, Visual and Electronic Content
projects.amongstmyselves.com
