Vegas pro 13 – track glow bad (buggy) behavior
László Kovács replied 10 years, 1 month ago 4 Members · 15 Replies
Graham Bernard
August 3, 2016 at 11:27 am -
László Kovács
August 3, 2016 at 12:32 pmThanks for all your support!
That means I’m not alone, and the problem is not only in “my device”.Here’s a veg, so anyone can test easily:
10372_2dglowzeroblurtest.veg.zipUnfortunately Sony border FX does work only for images with a matching aspect ratio to the project aspect, and that’s rarely the case 🙁
Otherwise empty, transparent areas appear between the image and the border.Best regards
Eric Dettman
August 3, 2016 at 8:16 pmIn project properties, do you have full-resolution rendering quality set to good or best. If it is set to best, try setting it to good. This will resolve the issue if it is due to bicubic scaling w/integration talking place.
MAGIX see.feel.hear.create
László Kovács
August 4, 2016 at 5:11 amHi Eric,
Good to see someone here from Magix 😉
I tried the setting you mentioned. Unfortunately does not help.
It was set to best, I set it to good. Nothing changed regarding this phenomenon.Kind regards
