Activity Forums VEGAS Pro Vegas Pro 13 Not Detecting VST Plugins
  • Vegas Pro 13 Not Detecting VST Plugins
    Posted by Ben Potts on January 26, 2015 at 4:13 pm
    I have the plugin Dll. file in the Folder i set vegas to use and then i refreshed, still not showing anything…any help?
    Ben Potts replied 11 years, 7 months ago 4 Members · 8 Replies
  • 8 Replies
  • Steve Rhoden
    January 26, 2015 at 4:59 pm
    Which VST Plugin Vegas not picking up?
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • Ben Potts
    January 26, 2015 at 5:02 pm
    Newblue Motion Effects
  • John Rofrano
    January 26, 2015 at 10:28 pm
    [Ben Potts] “Newblue Motion Effects”
    I believe Motion Effects are video effects and VST’s are audio effects so one has nothing to do with the other.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Steve Rhoden
    January 27, 2015 at 1:36 am
    Newblue Motion Effects? Thats not a VST plugin Ben!
    You are going about whatever you are doing all wrong.
  • Ben Potts
    January 27, 2015 at 6:45 am
    I see, So how can i get Newblue Motion Effects to work then? the installer installs to the defualt location but does not show in vegas…
  • Derek Moran
    January 27, 2015 at 12:00 pm
    I had problems with NewBlueFX not showing up once. The problem seemed to be caused by having too many different versions of Vegas Pro and Movie Studio Platinum installed on the same machine. I had 32bit & 64bit versions in the mix as well.
    Solution:
    1. Un-install most older versions of Vegas & MS and only leave the newest 64bit versions of Vegas and Movie Studio installed. Make sure to get rid of 32bit versions if not needed – I think this may have been the actual cause.
    2. Un-install all NewBlueFx products and re-boot computer.
    3. Re-install all NewBlueFx but this time ONLY install the 64bit OpenFX versions. Make sure to deselect all other options that are automatically selected by the NB Installer.
    4. Final step if needed was to perform full program reset, to make sure Vegas cache was cleaned and renewed.
    Do this to reset:
    Turn Vegas Off.
    Hold down CONTROL and SHIFT keys at the same time AND ALSO AT THE SAME TIME double click program icon on Desktop to Boot program.
    Window will pop up.
    Select Delete Cache and Yes.
    This will restore program to Factory Default Settings.
  • Ben Potts
    January 27, 2015 at 12:53 pm
    That’s the thing, i only have one Vegas installation
  • Ben Potts
    January 27, 2015 at 2:00 pm
    Nevermind, i fixed it my going into regedit.exe and deleting Newblue and then by installing again, thanks guys
