Activity Forums VEGAS Pro Vegas Pro 13 keeps crashing when stabilizing 4K video
  • Vegas Pro 13 keeps crashing when stabilizing 4K video
    Posted by Linus Petraitis on August 17, 2016 at 6:27 am
    Does anyone experience something like that? I get a crash like every 2 or 3 clips. I can’t edit 4K videos. What the hell?
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 13.0 (Build 453) 64-bit
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:\Program Files\Sony\Vegas Pro 13.0\proDADMercalli20.dll
    Fault Address: 0x00007FFD64CA6B36
    Fault Offset: 0x0000000000046B36
    Fault Process Details
    Process Path: C:\Program Files\Sony\Vegas Pro 13.0\vegas130.exe
    Process Version: Version 13.0 (Build 453) 64-bit
    Process Description: Vegas Pro
    Process Image Date: 2015-06-05 (Fri Jun 05) 13:53:04
    Ryan Gray replied 8 years, 11 months ago 3 Members · 2 Replies
  • Guðmundur Sigmundsson
    August 23, 2016 at 11:56 am
    I´ve been experiencing the same behaviour.
    It is really unstable but to mee it seemt like it always occurs on the same files. Meaning that if it works on some file I can repeat that multiple times without it crashing. Similary if it fails I can be sure it is going to fail everytime I try again.
  • Ryan Gray
    September 25, 2017 at 10:05 pm
    I’m having the same issue. Have either of you experienced any kind of resolution or workaround yet?
