Activity › Forums › VEGAS Pro › Vegas Pro 13 crashing probelm.
  • Vegas Pro 13 crashing probelm.
    Posted by Dev Mehta on May 15, 2015 at 9:21 pm
    Hello,
    I’m having a problem with rendering in Sony Vegas Pro 13 for a while.
    As soon as I press the ‘Render as’ button, the application crashes.
    There is no way I can render my videos.
    On crashing, I get the following info:
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 13.0 (Build 290) 64-bit
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:\WINDOWS\SysWOW64\tsccvid64.dll
    Fault Address: 0x000000007F845DEF
    Fault Offset: 0x0000000000005DEF
    Fault Process Details
    Process Path: C:\Program Files\Sony\Vegas Pro 13.0\vegas130.exe
    Process Version: Version 13.0 (Build 290) 64-bit
    Process Description: Vegas Pro
    Process Image Date: 2014-04-10 (Thu Apr 10) 04:57:08
    Can anyone help me? This is kinda urgent.
    Thanks! 🙂
    Steve Rhoden replied 11 years, 4 months ago 3 Members · 5 Replies
  • Steve Rhoden
    May 15, 2015 at 11:59 pm
    First thing! Download and install the latest build 444 and see
    if it goes smoothly.
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • John Rofrano
    May 16, 2015 at 5:33 pm
    [Dev Mehta] “Fault Module: C:\WINDOWS\SysWOW64\tsccvid64.dll”
    That is the TechSmith Screen Capture Codec used by Camtasia and SnagIt. Do you have either of these installed? If so, I would try uninstalling them temporarily to see if it fixes the problem. If it does, try re-installing from the latest version and see if it works. If it breaks Vegas Pro again, contact TechSmith and see if they can help.
    Of course updating to the latest Vegas Pro Build 444 before trying this as Steve suggested.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Dev Mehta
    May 16, 2015 at 6:10 pm
    Hey John!
    I did some more looking into. Turns out it was the .dll files of Camtasia Studio 8 I uninstalled a few months ago that was causing the problem. So I went ahead and deleted it. Later, It crashed becaause of another TechSmith Plug-In. So I went ahead and deleted all plug-ins related to TechSmith since I don’t use their softwares anyway.
    This solved all my problems related to Vegas Pro crashing.
    Hope this would help any of you.
    Thanks for all the help anyaway!
  • John Rofrano
    May 16, 2015 at 6:52 pm
    [Dev Mehta] “I did some more looking into. Turns out it was the .dll files of Camtasia Studio 8 I uninstalled a few months ago that was causing the problem.”
    That’s what I thought it was. Glad removing them fixed it for you.
    ~jr
  • Steve Rhoden
    May 17, 2015 at 1:06 am
    Glad you got it sorted too my friend, along with John’s help.
    Still update Vegas however.
