Activity Forums VEGAS Pro Vegas pro 13
  • Vegas pro 13
    Posted by Greg Buzzell on December 22, 2015 at 7:57 pm
    Can I embed an SCC closed caption file to a video? When it is embedded, what format can I export it as so that the CC will be embedded in the video for broadcast?
    John Rofrano replied 10 years, 9 months ago 2 Members · 5 Replies
  • John Rofrano
    December 22, 2015 at 8:27 pm
    [Greg Buzzell] “Can I embed an SCC closed caption file to a video? When it is embedded, what format can I export it as so that the CC will be embedded in the video for broadcast?”
    Yes. When you render to XDCAM HD/XDCAM HD422 MXF formats, captioning markers are embedded in the media file. Also when you render to MPEG-2 format, captioning markers are encoded in ATSC format. Those are the only two formats that support embedded closed caption with Vegas Pro. I would use Sony MXF HD422 1080p 50Mbps for broadcast delivery.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Greg Buzzell
    December 22, 2015 at 10:25 pm
    Thanks for the info. However, I need to render either to MOV or MPEG2. I have noticed that Vegas has trouble rendering to MPEG2 in 1080i when you try to do 20mbytes for a bit rate. Any suggestions on that?
  • John Rofrano
    December 22, 2015 at 11:34 pm
    [Greg Buzzell] ” I need to render either to MOV or MPEG2″
    Did the broadcaster give you any specifications? If so, what are they? Are they expecting MPEG2 in a MOV container?
    [Greg Buzzell] “I have noticed that Vegas has trouble rendering to MPEG2 in 1080i when you try to do 20mbytes for a bit rate. Any suggestions on that?”
    Did you ask them if they can accept MXF format? Sony MXF is MPEG2 @ 50 Mbps which sound like exactly what you need.
    ~jr
  • Greg Buzzell
    December 23, 2015 at 9:14 pm
    It turns out you are correct. They can except MXF format. I will be trying that. thanks.
  • John Rofrano
    December 24, 2015 at 3:36 pm
    [Greg Buzzell] “It turns out you are correct. They can except MXF format. I will be trying that. thanks.”
    Great! You want to render to Sony MXF using the HD422 1920×1080-60i 50 Mbps template. That will retain the closed captions. (of course use 50i, or 24p if that’s more appropriate but you get the idea)
    ~jr
