Vegas Pro 12 Render takes too long
Posted by Gabriel Solomon on January 2, 2013 at 4:51 amI just finished editing a video in vegas pro 12 and am trying to render the file to mpg so i can make a dvd in DVD architect. the video is 1:55:00 minutes long. The render is taking a long time and the dialog box states that it will take almost 3 hours to render.
IN vegas pro 11, it would have taken less than 1 hour. Any suggestions on what to do to make the render process faster?
Gabriel Solomon
LifeCapture Images
http://www.lifecaptureimages.comJohn Rofrano replied 13 years, 8 months ago 5 Members · 10 Replies -
Paul Anderegg
January 2, 2013 at 11:10 amI am going to guess you know enough about the program to have selected the proper GPU settings etc……..can you tell us what your original file/s format specs are, and your final output….I am assuming standard mpeg2 DVD?
I render DVCPRO AVI files to SD MP4, and it takes Movie Studio 12 about 30 seconds per minute to render on my new i7 laptop. My old i3 laptop does the same task at about 1 minute 30 seconds per minute, so hardware does make a difference!
I made a 35Mbps 1080i MP4 file to test rendering speeds if I upgrade to an HD camera, and it takes about 45 seconds to render a minute of that to SD MP4.
Paul
Gabriel Solomon
January 2, 2013 at 3:52 pmHi Paul.
I am using Vegas Pro 12
My settings In Tools – options – Video are set to
Dynamic Ram 200MB
max rendering threads 16
GPU Acceleration of Video processing – (set to my Nvidia Graphics cardMy source files are NXCam AVCHD, M2TS files
I am editing and trying to render the finished project to the DVD Architect templateI customized the template settings using a bitrate calculator and i am trying to render my timeline. My 11 minute test movie is taking 17 minutes to render.
My computer is an i7, 3.4ghz with 8gb of ram and windows 7 64 bit
I have a Nvidia GeForce GTX550 1gb graphics cardIn vegas 11, the render time was approximately half the time of the movie
Gabriel Solomon
LifeCapture Images
http://www.lifecaptureimages.com -
Gabriel Solomon
January 2, 2013 at 5:14 pmAfter speaking with Sony, I was advised go to the OPTIONS menu, go to PREFERENCES, then the VIDEO tab.
by the option for GPU acceleration of video processing, make sure it is set to offThis worked.
Thank you Sony Creative Software support staff!!!
Gabriel Solomon
LifeCapture Images
Paul Anderegg
January 2, 2013 at 7:46 pmThat makes a lot of sense……perhaps that it a Sony “inverse GPU” feature! Haha. When I uncheck my GPU acceleration, the rendering takes an extra 4 seconds per minute, go figure.
Paul
James Houghtaling
January 4, 2013 at 2:55 amDid Sony explain why you should turn off GPU? Do you have an incompatible or trouble-prone card?
My Hardware:
Core i7 2.67GHz; Nvidia GTX580, 12 gig RAM Win7 64bit.My Software:
Vegas Pro V11 with Boris Continuum Complete 8, VASST Ultimate S; Bluff Titler; AE5; PhotoPaint and other stuff. -
John Rofrano
January 4, 2013 at 1:38 pmIt’s interesting that an NVIDIA GeForce GTX550 degraded the performance over an Intel Core i7, 3.4ghz CPU. I know people are using the GTX570 with good performance. I guess the GTX570 is more powerful than the GTX560 which is more powerful than the GTX550 which apparently isn’t as powerful as a Core i7. This is the problem with hardware assistance… the hardware that’s assisting needs to be more powerful than the hardware you already have. 😉
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Andrew Phillips
January 6, 2013 at 5:56 pmI suppose that means my Gforce 9600GT needs shut off too. 🙂 Seems like this feature should be “hardware assist” with *assist* being a keyword. Assist would help render the extras on top of the normal CPU operations, not slow things down.
-Andrew
John Rofrano
January 6, 2013 at 6:31 pm[Andrew Phillips] “I suppose that means my Gforce 9600GT needs shut off too. :)”
Yea, that would look to be a “bottleneck”.
[Andrew Phillips] “Seems like this feature should be “hardware assist” with *assist* being a keyword. Assist would help render the extras on top of the normal CPU operations, not slow things down.”
It hands the task over to the GPU. It doesn’t evaluate the GPU to see if the CPU could do it quicker. It’s up to you to configure your system properly where the GPU is more powerful than your CPU. If not, it’s like you are delegating the job to the slowest member of the team. Either replace that member or stop delegating.
~jr
James Houghtaling
January 7, 2013 at 5:48 pm[John Rofrano] “the hardware that’s assisting needs to be more powerful than the hardware you already have.”
Makes sense, now if only there was a cross reference comparing all possible GPUs to their matched CPUs we wouldn’t have to guess. I wonder and guess that the speed of the render relies on the type of processing that’s going on in your timeline. Making the decision to use GPU that much more unpredictable. I’ve got a 580 and made the switch to GPU… now I question if that’s the right choice. I’ve only got an old Core i7 920 @ 2.67GHz so I thought the newer GUP would be the right choice.
My Hardware:
John Rofrano
January 7, 2013 at 7:31 pmYea, I don’t think it’s a guaranteed pairing of this GPU with that CPU. It also depends on how the software uses the GPU. My only points was that pairing a modern day CPU with a 3 year old GPU is asking for trouble. I agree that it would be nice to understand how Vegas Pro performs with various GPU’s and CPU’s.
On Sony’s GPU Acceleration page they do compare the NVIDIA GeForce GTX 570, AMD Radeon HD 8670, NVIDIA Quadro 5000, and AMD FirePro V8800. That should at least give you an indication of relative performance using an Intel Core i7 960 3.2 Ghz CPU.
BTW, this is one of the reasons why I would recommend the NVIDIA GeForce GTX 570 if you can’t afford the NVIDIA Quadro 4000 that I have. At least you know that Sony tested with it! 😉
~jr
