Vegas Pro 12 not able to read files encoded in Apple ProRes
Steve Rhoden replied 11 years ago 6 Members · 15 Replies
Wayne Waag
August 19, 2015 at 10:44 pmEven better (also free), you can open a one line Avisynth script in Virtualdub, use the UT Video lossless codec, selecting the YUV422 BT.709 VCM preset and the resulting file should be identical to the orginal ProRes file. Rendering is pretty quick.
wwaag
Steve Rhoden
August 20, 2015 at 1:59 amHandbrake is the best free option to choose!
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
https://www.facebook.com/FilmexCreativeMedia -
Rick Shorrock
August 20, 2015 at 2:20 amI ended up using MPEG Streamclip as a workaround. I imported a clip, using the ‘Export to QT’ settings, I used the Avid DNxHD codec, changed the color space to RGB and rendered the file uncompressed. I was then able to drop the resulting clip in a track over my main video track in Vegas, and using track motion on the upper track and then picking ‘screen’ as the overlay method, which rendered the black background clear. These are mainly effects tracks like lighting, bokeh and flares that I’ll convert as I need to.
John Rofrano
August 20, 2015 at 3:57 amGlad you found a solution. Avid DNxHD is a good digital intermediary codec to use.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Steve Rhoden
August 20, 2015 at 5:13 pmThat is good!
