Activity Forums VEGAS Pro Vegas Pro 11(release 701)/Vegas 12 Playback Problems & More
  • Vegas Pro 11(release 701)/Vegas 12 Playback Problems & More
    Posted by Alan Fleury on October 12, 2012 at 6:47 pm
    I have been running Vegas 11 Pro build 683 on 2 machines. One running windows 7 64 bit, the other windows Vista 64 bit. The machines have NVidia Cards (550 Ti & 570 HD). Both are 3.2 i7 processors (an 8 core machine & 12 core machine) with 6Gb & 16Gb RAM respectively. Version 11 build 683 runs quite well. The upgrade to Version 11 build 701 & subsequesntly to Version 12 causes major crashing. I can’t even playback video on the timeline without a crash. Both machines stutter during playback with or w/o GPU acceleration activated. I also noticed that V11 build 683 uses about 20% CPU resources when playing video (displayed in the resource monitor. V12 uses over 70% GPU resources when playing video on the timeline??? All my video drivers are up to date. I can’t even run V12 at this time … all my work has to be done in V11 build 683.
    Tim Mccallister replied 13 years, 5 months ago 4 Members · 7 Replies
  • 7 Replies
  • Steve Rhoden
    October 12, 2012 at 7:15 pm
    Have only one version of Vegas installed on each
    system (Preferably Vegas 12).
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    1-876-832-4956
  • Alan Fleury
    October 12, 2012 at 7:53 pm
    Should it matter? I have often run 2 versions and never experienced a problem. Also, pre release V12, the release of V11 build 701 caused the same problems … I had to roll back to V11 build 683
  • Steve Rhoden
    October 13, 2012 at 5:20 am
    I would not have mentioned it if it didnt matter. Vegas 11
    was not too wholesome, it had issues thru all its builds,
    Vegas 12 however is stable in its first release and in
    certain circumstances, i discovered that having them both
    on a system affects Vegas 12 stability.
    There is never really a need running two versions of Vegas
    if you have the most current release.
    Steve Rhoden
    (Cow Leader)
    1-876-832-4956
  • Darren Poulton
    October 13, 2012 at 6:58 am
    I had this exact same problem.
    It took me ages to figure out but when I recreated my project from scratch in Vegas Pro 12, everything worked fine.
    It would appear that at some point the project was trashed by Vegas Pro 11.
    I could tell this as I had several VFX on my video events that I had removed (trials of product had expired and watermarks were present), but the watermarks were still visible.
    Now, everything works great with only the occasional crash.
    Darren
  • Alan Fleury
    October 13, 2012 at 2:29 pm
    Thank You … it’s really weird. I uninstalled vegas 11 & 12, tried installing only vegas 12 and still, when opening a V11 project, it stuttered & then crashed on video playback. BUT when I rebuildt the project in vegas 12 only by pulling the original media back into the project, it seemed to run much better!
    Thank You
  • Darren Poulton
    October 15, 2012 at 5:59 am
    Yep tis strange indeed.
    Glad my pain could help 🙂
  • Tim Mccallister
    April 10, 2013 at 7:47 pm
    [Steve Rhoden] “I would not have mentioned it if it didnt matter. Vegas 11
    if you have the most current release.”
    Two points, or questions:
    — John Rofrano has often said in the forums, that he has up to 3 older versions of Vegas installed on the same machine, that this is one of Vegas’ strengths.
    — I’ve had to keep past versions of Vegas installed due to the latest version having problems opening up older nested VEG files.
    Indie Filmmaker
