Activity Forums VEGAS Pro Vegas Pro 11.0 Render pausing after every second rendered.
  • Vegas Pro 11.0 Render pausing after every second rendered.
    Posted by Adrian Fox on February 11, 2012 at 9:20 pm
    I have tested this with two different framerates, I rendered 24 fps and it renders 24 frames quickly, then pauses for 2-3 seconds, then proceeds to render the next 24 frames, then pauses, and so on, I have tried this using 29 fps aswell and the exact same happens but renders 29 frames between pauses, so it is probably safe to say it pauses between every second rendered, and this is slowing down the render significantly, and it is taking 3x longer than it should, has anyone encountered this problem before and maybe knows how to fix it? thanks.
    Dustin Moore replied 14 years, 6 months ago 6 Members · 6 Replies
  • Steve Rhoden
    February 11, 2012 at 10:04 pm
    Im still trying to figure out exactly what you are saying…
    but never encountered anything that may be similar using Vegas 10.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    1-876-832-4956
  • Adrian Fox
    February 11, 2012 at 10:16 pm
    I probably didn’t word it very well, sorry, basically, when I render a video, Vegas renders 24 frames, or 29 frames, depending on what the framerate is, e.g if I was rendering 60fps, Vegas would render 60 frames, and then pause for 2-3 seconds, then continue to render another set of 24, 29, 60 frames, and so on, hopefully this was easier to understand, and I have never encountered this problem before either, I just upgraded from 10.0 and now I have this problem.
  • Mike Kujbida
    February 11, 2012 at 10:38 pm
    Are you rendering to WMV format?
    It’s been doing this to me for several versions of Vegas.
  • Jeff Schroeder
    February 12, 2012 at 12:31 am
    I have only seen this in WMV.
    Windows 7 64-bit, ASUS P6X58D, i7 960 3.20GHz, 24.0GB DDR3, 12TB connected storage
    http://www.narrowroadmedia.com
  • Kelly Basden
    February 12, 2012 at 1:16 pm
    WMV is the clue.I’ve noticed this as well.
    It’s all about the music.
  • Dustin Moore
    February 13, 2012 at 6:05 pm
    If you are rendering to an codec that uses interframe
    compression it is quite common that the video editing
    program feeds a complete GOP to the codec and then the
    codec has figure out how to distribute all of the bits
    among the frames in the GOP to maximize picture quality
    while maintaining the bitrate.
    This is totally normal. If you want it to run faster lower
    the quality settings or use a more optimized codec like
    x264.
