Activity › Forums › VEGAS Pro › Vegas Pro 11 update out
  • Vegas Pro 11 update out
    Posted by Angelo Mike on November 8, 2011 at 3:13 am
    …and it’s still turning all my footage from the correct 1.33 aspect ratio to 1. Vegas 10 doesn’t have this problem. I uninstalled versions 9, 10, and 11 (AGAIN), restarted my computer, and installed 11 with the update to see if it helped, since Sony sent me a link to the Vegas 11 update as responses to my complaints about Vegas making my footage into the incorrect aspect ratio until I changed each piece of media individually, but it still does the same thing.
    Is there any way to get Vegas 11 to stop doing this?
    Edit: And I tried uninstalling all versions of Vegas/reinstalling Vegas 11 because I’m getting an avi.dll error every time I open a project, so I can’t work.
    Angelo Mike replied 14 years, 10 months ago 3 Members · 13 Replies
  • 13 Replies
  • Ted Snow
    November 8, 2011 at 5:28 am
    11 evidently has some bugs to work out. Today I booted my computer, ran the 32 bit version to work on some audio. The project loaded up fine but when I hit the space bar to play, an error message popped up and said that “Sony Vegas has quit working and will close”. I started Vegas again, opened up the same project and the same thing happened again when I hit play. Upon starting Vegas the third time and opening the same project…I worked on the project without any problems.
    I was lucky for about a week without problems…but the gremlins have invaded.
    ASUS P8P67 Deluxe MB
    EVGA GeForce GTX 560 Ti 1 GB DDR 5
    Intel i7 2600k 3.4 Ghz
    Corsair HX750 power supply
    Two Seagate Barracuda 500g SATA III drives
    16 Gig G.Skill Ripjaws DDR3 1600
    Canopus ACEDVio card
    Thermaltake V9 BlacX Edition case
    Xigmatek Dark Knight CPU Cooler
    Win 7 Pro
    VEGAS 8.0
    VEGAS 11.0 32 & 64 bit
    Sony VX2100
    Sony HVR-Z7U
    Sony HDR-CX130
    Alesis HD24
  • Angelo Mike
    November 8, 2011 at 6:37 am
    Now more avi.dll crashes.
  • Steve Rhoden
    November 8, 2011 at 7:41 am
    Often times im still at a loss as to why, why
    everyone has a different experience using the exact same software.
    I know given the fact that everyone’s system is varied in specs and
    so forth…Its still strange…..ahhhh
    Angelo, i wish i could help your situation, i understand the
    frustration.
    By the way, What are your system specs?
    And what source you get the majority of your workflow (media) from?
    Steve Rhoden
    (Cow Leader)
    Film Maker
    Filmex Creative Media.
    1-876-832-4956
    https://filmex-creative-media.blogspot.com/
  • Angelo Mike
    November 8, 2011 at 2:03 pm
    Double post.
  • Angelo Mike
    November 8, 2011 at 2:06 pm
    I have an i7 950 3.07 Ghz CPU
    12 GB DDR3 RAM
    GeForce GTS 450
    Windows 7
    I transfer all my footage from my Canon Vixia HF S21s to my computer via a transfer utility and usb cable. It’s AVCHD footage, which I then run through Cineform Neoscene to turn into avi. I keep all my footage and projects on external hard drives, which are actually internal hard drives that are in enclosures that run to my computer through an eSata cable.
    I was able to open my projects for at least a few seconds last night and preview some footage. Now I’m getting the avi.dll error, again. I tried a fix that someone posted on Creative Cow a year ago (replace the avi.dll file with the one from the 32 bit version of Vegas), and it would just make Vegas hang and crash.
    I want to reformat everything on my computer, but my friend built my computer and has my copy of Windows 7, and he hasn’t been able to get me the copy of Windows 7 for whatever reason.
    What’s really strange is that if I open a new project and drag some of the media into the project media bin that is in the project that is crashing, Vegas runs fine. But I was well into my project, and this keeps happening on projects that I’m well into.
    http://www.scenethroughglass.com
  • Steve Rhoden
    November 8, 2011 at 2:31 pm
    That extra step of converting your AVCHD Clips to avi
    using Neoscene sends a slight chill down my spine….lol
    I can bet that is a factor why you occasionally have some issues,
    because you have a decent machine and the correct drive management.
    Also, a clean install as you mentioned, would be a good start.
    Steve Rhoden
    (Cow Leader)
    Film Maker
    1-876-832-4956
  • Angelo Mike
    November 8, 2011 at 2:50 pm
    I know, changing files to avi I think may be an issue. But I don’t have much of a choice unless I sell my cameras and get new ones. My Canon Vixia HF S21s were the best deal I could get for all they do, which is a lot for me. I have three and shoot events with them, and that’s how I make a living. I defragged my computer, cleaned up temporary files, removed the only game I had installed, did a virus scan, uninstalled all my Vegas software and reinstalled 10, did the fix with the 32 bit version of the avi.dll file, which just makes Vegas hang and then crash. Does anyone really think that reinstalling Windows will fix the problem?
    And I have the latest version of Cineform, 5.5.4. Should I just sell my cameras and get Sony ones? I would happily switch editing software, I’d almost rather switch cameras since, when Vegas works, it’s superior to all other editors to me.
  • Steve Rhoden
    November 8, 2011 at 4:07 pm
    Do you have any issues at all rendering and working with
    the native AVCHD footage from your cameras (apart from maybe
    the lag while editing it on the timeline)?
    Steve Rhoden
    (Cow Leader)
    Film Maker
    1-876-832-4956
  • Angelo Mike
    November 8, 2011 at 4:10 pm
    No, and I’m trying to just start over with the AVCHD footage. It does stutter when I put in any effects or transitions, but I suppose I’ll just get more RAM.
    Edit: Wow. I can actually drag more than 8 clips at a time into the project media without Vegas crashing.
  • Steve Rhoden
    November 8, 2011 at 4:37 pm
    lol….Well, you see that most of the issue derives from
    the Cineform conversion.
    If i were you, i would find a way to eliminate that conversion
    process from my workflow, and just deal with the little
    stuttering during edits.
    Noticed several complaints regarding some Cineform issues also.
    Steve Rhoden
    (Cow Leader)
    Film Maker
    1-876-832-4956
