Activity › Forums › VEGAS Pro › Vegas Pro 11 to AE 5.5
  • Vegas Pro 11 to AE 5.5
    Posted by Rosh Kadri on December 2, 2011 at 5:24 am
    Hi guys, we used to be able to save an Avid legacy AAF file and send it out to AE with all cuts lined up. Is there a way to do this in pro 11, i’ve tried and EDL and an XML but none worked. Any ideas, script, anything please?
    Brian Scott replied 14 years, 5 months ago 4 Members · 4 Replies
  • Dave Haynie
    December 2, 2011 at 7:01 am
    You can still save an AAF (modern or legacy) from Vegas 11… you just have to be using 32-bit Vegas. Why? I believe it’s because the Advanced Media Workflow Association has not release a 64-bit version of the AAF libraries (though some NLE makers have done their own).
    -Dave
  • Rosh Kadri
    December 2, 2011 at 9:18 am
    Thanks for the reply, it seems to me that the purpose here is to keep it in vegas. I wonder why no 64bit AAF, that kinda sucks. For now though, im just gonna export a standard AVI or Quicktime, re-cut the edits and composite 🙁
  • Mark Harmer
    February 28, 2012 at 10:19 am
    There is a script that works with 64-bit Vegas into AE – basically it reads the txt file and then converts. It works!
    The download link is here: https://rghost.net/26269221
    Within the zip file are some instructions on where to install the .jsx file
    Hope you find it useful – I joined this list because I’ve found this a great forum in the past, and struggled with finding a solution to AE import from Vegas 11. Now to learn how to get it back out!!
    Cheers
    Mark
  • Brian Scott
    April 22, 2012 at 8:46 pm
    As long as you are replacing individual shots – just load them as takes in vegas. Then you can switch between versions to compare
    Brian Scott
    President
    Image Design Productions, Inc.
