Activity Forums VEGAS Pro Vegas pro 11 STABILIZER CRASHES at 99%
  • Vegas pro 11 STABILIZER CRASHES at 99%
    Posted by Demetris Christodoulides on August 15, 2012 at 6:59 pm
    Whenever i try to stabilize a subclip i create via right click – media fx -sony stabilize – apply, it stucks at 99% and crashes the programme with this error message:
    Vegas Pro 11.0
    Version 11.0 (Build 595) 64-bit
    Exception 0xC0000005 (access violation) READ:0x0000000000000034 IP:0x000000003B254BA8
    In Module ‘Stabilize.ofx’ at Address 0x000000003B250000 + 0x0000000000004BA8
    Thread: exception in OFX plug-in ID=0x1930 Stack=
    Does it with either GPU on OR off, with different audio devices selected, and with either
    video settings tab in programm properties version1 = default
    dynamic ram preview max (mb) 200, max available 16gb
    maximum number of rendering threats: 16
    OR (but still crashes) with video settings tab in programm properties version2
    dynamic ram preview max (mb) 0, max available 16gb
    pc specs:
    core i7 *2nd generation 2600k overclocked at 3.4GHZ (8 core)
    16gb ram, all the same brand and model. osz at 1600Mhz
    nvidia gtx580 by Asus
    ssd disks, one intel (os) and one ocz vertex sataIII (project disk)
    sony vegas project specs:
    https://img860.imageshack.us/img860/1363/vegasproblemwithstabili.jpg
    video material specs:
    2 channels, 1 shot with panasonic sdt750 avchd @ 1080p 50fps
    1 shot with sony fx1 1080i @ m2t (mpeg) hd1080i, 50fps
    2ch48khz sound
    Wtf is wrong? I am in the middle of a 3 hour concert programme and it just begun to do that, it didn’t do it up to now!! What’s wrong, any ideas? thank you very much in advance.
    Paul Mcdermott replied 13 years, 6 months ago 4 Members · 4 Replies
  • Angelo Mike
    August 15, 2012 at 7:45 pm
    This happened to me constantly, so I just gave up on using it. Report it to Sony.
  • Mikhail Petrushin
    August 15, 2012 at 10:06 pm
    Quite often it crashes for me too (I reported 3 times about it and sent them zip archive that can be used for reproduce crash, however 2 times they just closed my ticket).
    First of all the project settings should match media settings.
    You can try cut one frame on the beginning and/or one frame on the end of the problematic fragment. Then create a new subclip and stabilize it.
    This workaround works in my case (1080-50p project settings and footage).
  • Demetris Christodoulides
    August 15, 2012 at 11:21 pm
    thank you Mikhail Petrushin !!!! it worked!
  • Paul Mcdermott
    February 21, 2013 at 3:51 pm
    Double thank you. I had a lot of problems with SV11. At the moment it’s running pretty well, but every now and again the stabiliser would not “like” a clip and crash the program.
    Your work around works!
    Paul
