Activity › Forums › VEGAS Pro › Vegas Pro 11 loading long files over 5GB
  • Vegas Pro 11 loading long files over 5GB
    Posted by Tom Owen on December 1, 2011 at 9:18 pm
    I use a Panasonic HMC 150. Because it formats the SD cards in FAT 32, there is a 4GB limit on the length of the file. That works out to about 15 minutes.
    When I shoot a long-form show (30-60 min or more) and load the file chunks to the timeline. I get audio dropout and sometimes black frames at the transition point. I have not found any function in Vegas that will cure that problem.
    I have found a program call tsMuxer that will stitch all of the file chunks together using a binary copy technique. On drives formatted to NTFS it will create one long file. I suspect the practical limit is around 20GB, but the shorter ones work fine.
    One problem. Vegas appears to load from the media bin without a problem, but it only puts 1:30 of the clip on the time line.
    I did find that Corel Video Studio 4 will happily accept the file at any length and play it back flawlessly. As will Premiere Elements, although it takes a long time to digest it.
    Does anyone have a solution? And buying a $1600+ program is not the answer!
    Tom Owen
    Tom Owen replied 14 years, 9 months ago 2 Members · 4 Replies
  • Dave Haynie
    December 2, 2011 at 8:39 am
    I’m an HMC40 user… it has a similar behavior.
    First of all, you don’t need tsMuxer to join files, and in fact, I’m not sure that’s a good idea. When your Panny breaks files up, it’s breaking them exactly at the 4GB mark. So there’s no logical boundry there.. it’ll break in the middle of any frame. That’s why you can sometimes get a dropout at the transition point.
    Because of this, all you need to do is concatenate the pieces into one large file. I have historically used a Cygwin shell command for this:
    > cat 00000.MTS 00001.MTS 00002.MTS >thewholeschmeggie.mts
    But these days I get lazy and use JD Design’s “File Concatenate/Split Context Menu” application, which basically adds this function as a Windows shell extension.
    As for the cut-off… I don’t have anything recently that went over 1:30 in a single take. But be careful about mixing takes. In theory, you can concatenate MPEG-2 transport stream files all day, and Vegas should read them. But I think you get some kind of end marker when you stop the camcorder, and that’s used by many programs in the usual PC world (MPEG2-TS was defined originally for never-ending streams, like satellite/cable TV) to signal an end-of-stream. So if you concatenate multiple files in a single take, great. If you put together two different takes, many programs will only see one of them. Check what the Windows file browser thinks of your file lengths, and see if they match what Vegas believes. I’ve done a little experimentation here, and was able to create a 95 minute file that shows up in Vegas and Windows as a 44 minute file, based on where one of the streams ended.
    -Dave
  • Tom Owen
    December 5, 2011 at 4:57 pm
    Dave, I tried ConCat/Split from JD Designs. It did the concatenation, but soften the files unacceptably. What was crisp, turned fuzzy. I’m going back and see what tsMuxer will do. In my original test it did not degrade the files.
    Thanks for your suggestions. I’ll let you know what I find.
    Incidentally, I fondly remember the Commodore days. I had one of the early one’s with 7″ drives. I wanted the Amiga so bad I could taste it. Our current machines do so much, but I don’t think we appreciate them.
    Tom
  • Dave Haynie
    December 7, 2011 at 6:10 pm
    [Tom Owen] “Dave, I tried ConCat/Split from JD Designs. It did the concatenation, but soften the files unacceptably. What was crisp, turned fuzzy. “
    All that does is concatenate the files… it doesn’t even understand the file structure, much less change anything about the video. I claim it can’t make the video fuzzy — something else has to be wrong.
    TSMuxer is also totally unable to change anything about the video, but it does re-mux the media stream. Which is also not a problem, as long as the end of file condition doesn’t trip it up. The real question I have for this merge operation is whether TSMuxer really handles abrupt EOFs properly.
    -Dave
  • Tom Owen
    December 7, 2011 at 7:12 pm
    You are correct. tsMuxer and ConCat/Split both do the same thing. And both will join files that have been broken in the camera. Incidentally, I erred in saying the chunks were 5GB. They are actually 4GB, almost to the bit.
    I’m a little embarrassed to admit it, but by digging deeper into both programs, I finally was able to make them work. Your observation that ConCat/Split is easier, is also correct. Simply selecting the files and clicking a couple of times to join them is a whole lot easier than opening a program, searching for files, etc.
    As for the “fuzziness” I complained about… well let’s just say I’m having the back focus on my camera checked. Fuzzy is not the fault of the joining programs.
    I would like to thank you for your insights and information. It provided valuable clues to resolving the joining problem. Now if the camera manufacturers would consider “fixing” the underlying problem, users would find their cameras easier to use.
