Vegas Pro 11 & K-Lite Codec Pack
George Tsiripas replied 14 years, 4 months ago 4 Members · 13 Replies
Tony Hall
April 23, 2012 at 5:17 amI wasted 2 days re-installing everything to fix a “Vegas (pro 10) stopped working” nightmare during a long edit (2 cams 2hrs). I’ll cut to the chase, the first hour edit was non-problematic but then the second half kept crashing. I remembered the un-manned cam stopped after the battery ran out, so I double checked the last clip (AVCHD) and sure enough it was corrupted at the end. When I removed it from the timeline, I never had another crash.
this probably applies to any corrupted highly compressed format like AVCHD that can cause Vegas 10 or 11 to become unstable and bail-out.
Double check your source files before you waste time looking under the hood. -
George Tsiripas
April 23, 2012 at 5:29 amThanks but I recently discovered that my ram is damaged so it must be that!
George Tsiripas
May 26, 2012 at 11:16 pmHi guys,
It’s me again. I replaced my damaged Ram and formatted my PC but the issue with the Blue Screen still exists. 🙁 I don’t really know what else I should do.
