vegas pro 11 build 425 constant crash
Posted by Troy Musson on November 22, 2011 at 7:17 amHi guys
I have serious problem with vegas 11 constantly crashing when ever im adding effects from sony and 3rd party Newblue sometimes the program will last for several minutes before crashing, it seems to crash randomly.Im pretty sure its not my system as its only vegas thats crashing. Previous version 10d was ok , 10e sometimes crashed but not often ,but 11 is all the time.. the error code is something like Clr then a load of numbers and it always mentions the sony vegas fx UI.
I have seen other people with the same problem but I dont see any soultions any where. Thanks.
Emilio Le roux replied 14 years ago 8 Members · 14 Replies -
Nigel O’neill
November 22, 2011 at 12:19 pmI would report the crashes to Sony.
My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 10e (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
Dave Roberts
November 22, 2011 at 2:33 pmI wish I could help you, but I can’t. Just wanted to back you up saying I`m having horrendous problems with Vegas 11 crashing. Simply editing or using FX can cause it to crash. I am using a brand new system, W7 64bit, and all drivers are bang up to date. 16GB RAM, I7 CPU and the weakest link is Vegas, it`s stunningly bad at the moment.
When it’s running, it`s amazing, but it goes for anywhere between 2 and 10 minutes before keeling over.
Have to say the Newblue Title is very fiddly, I am trying to do simple bullet points and there`s no obvious way to align them. Copy and paste doesn`t always work correctly either.
All in all, pretty poor after expecting so much!!
Dave Roberts
Concept Filming
Didcot,
OXON -
Angelo Mike
November 22, 2011 at 4:03 pmHappens to me to. The only way to avoid them for me is to do NewBlue effects somewhere on the timeline where there are no other events. Having other events seems to increase crashes significantly.
http://www.scenethroughglass.com
Stephen Mann
November 22, 2011 at 7:19 pmIf you are using a late-model nVidia/GeForce video card, the 285.79 Beta driver may fix some problems.
If you use the nVidia “auto scan”, it will likely report that you have the latest version.
https://uk.geforce.com/drivers
You do have the latest released version, but the 285.79-Beta driver seems to fix a lot of problems in Vegas installations.
https://www.nvidia.co.uk/object/win7-winvista-64bit-285.79-beta-driver-uk.html
Download it, install it and run Vegas. check for your “Vegas Bug” and let us know your results. You can always roll-back the latest released driver.
Steve Mann
MannMade Digital Video
http://www.mmdv.com -
Troy Musson
November 22, 2011 at 8:36 pmI am sing ATI graphics card and have just updated to the latest driver but still having the crashes. Heres the complete error code im getting.
CLR20r3
Problem Signature 01: vegas110.exe
Problem Signature 02: 11.0.0.425
Problem Signature 03: 4eae70ce
Problem Signature 04: Sony.MediaSoftware.VideoEffectsUI
Problem Signature 05: 11.0.0.425
Problem Signature 06: 4eae7068
Problem Signature 07: 541
Problem Signature 08: d
Problem Signature 09: System.NullReferenceException
OS Version: 6.1.7600.2.0.0.256.48
Locale ID: 2057same error code every time
Dave Roberts
November 22, 2011 at 8:49 pmThanks for this Steve. I have just installed 285.79 for my Geforce 560.
Will report back…
Dave Roberts
Concept Filming
Didcot,
OXON -
Dave Roberts
November 22, 2011 at 9:22 pmInstalled BETA drivers for GTX560, still constant random crashes. Disabled GPU acceleration, but still crashing.
Don’t believe it’s even TitlerPro related, Vegas ‘feels’ very buggy.
Dave Roberts
Concept Filming
Didcot,
OXON -
Dave Roberts
November 23, 2011 at 1:19 pmMiracle cure, been editing now for 20 minutes with no crash!!
Simple solution – uninstalled the NewBlue TitlerPro. One awful bit of software, so fiddly to create simple text on screen. I was adding characters but it was putting them in random places, impossible to align multiple paragraphs along the x axis, it was adding characters randomly. Gone back to ProType Titler and all is good! Phew.
Dave Roberts
Concept Filming
Didcot,
OXON -
Troy Musson
November 23, 2011 at 1:35 pmGood one , im afraid i havent been using newblue titler mine crashes when using the sony plugins, im going to try and clean the registry, ive found that it doesnt seem to crash on my laptop which is not equipped to edit video only a single core processor and 4gb ram. so will try the registry on my main pc.
Dave Roberts
November 23, 2011 at 4:00 pmNot such a miracle cure! Instead of crashing in two minutes, it now only crashes after about 20.
Looking on the bright side of life, it’s progress!
Dave Roberts
Concept Filming
Didcot,
OXON
