Activity Forums VEGAS Pro Vegas Pro 10c quits on load
  • Vegas Pro 10c quits on load
    Posted by Phil Seymour on May 2, 2011 at 8:31 am
    🙁 The old problem with loading projecys is back.. it stops somewhere between 10 and 43% saying Vegas has stopped, and then exits off the screen.
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 10.0c (Build 470) 64-bit
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4940_none_08e4299fa83d7e3c\MSVCR90.dll
    Fault Address: 0x00000000702AE41C
    Fault Offset: 0x000000000001E41C
    Fault Process Details
    Process Path: C:\Program Files\Sony\Vegas Pro 10.0\vegas100.exe
    Process Version: Version 10.0c (Build 470) 64-bit
    Process Description: Vegas Pro
    Process Image Date: 2011-01-02 (Sun Jan 02) 22:40:24
    Where is 10d? Although I don’t think it will solve the problem.
    Phil Seymour replied 15 years, 4 months ago 2 Members · 2 Replies
  • Roger Bansemer
    May 2, 2011 at 9:47 am
    This may not be the problem but I have occassionally saved my projects as a “save as” and made the mistake of saving in the same directory that had been saved to previously. Well, Vegas doesn’t overwrite the files, it makes new ones and adds 000 to the file name and you’re left with double files and a mess of new names clips.
    I’ve had trouble loading Vegas once this has happened. Check your files to see if you have a lot of extra clips.
  • Phil Seymour
    May 3, 2011 at 9:39 am
    Thanks for the idea.. but no, no extra files. The problem occurs before I get a chance to “save as” anyway. Stephen Mann came up with some thoughts, and for a while all was well, then like the Cat Who Came Back…. it did.
