Activity › Forums › VEGAS Pro › Vegas Pro 10 Project Loading Prob
  • Vegas Pro 10 Project Loading Prob
    Posted by Karl Reith on August 16, 2011 at 7:18 am
    Hi guys,
    Haven’t posted in a while, but i’ve run into what seems to be a HUGE problem! It’s prob nothing but hopefully you guys can help!
    I recently re-installed vegas pro 10 and then updated it (without opening any projects) with the Vegas 10e update! Now whenever I try opening a project (“pre” re-installation) vegas comes up with that soul sucking error dialogue saying vegas has stopped working. It loads the project until about 4 or 5% and then crashes.
    Now i got the details of the error report hopefully someone here can figure out what the problem is. I was working on 10e before the re-install and everything worked fine, I have no clue what changed??
    If you guys could help in any way I would be forever gratefull!!
    Here’s the error report:
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 10.0e (Build 738) 64-bit
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:\Program Files\Sony\Vegas Pro 10.0\vegas100.exe
    Fault Address: 0x0000000000000000
    Fault Offset: 0x0000000000000000
    Fault Process Details
    Process Path: C:\Program Files\Sony\Vegas Pro 10.0\vegas100.exe
    Process Version: Version 10.0e (Build 738) 64-bit
    Process Description: Vegas Pro
    Process Image Date: 2011-06-29 (Wed Jun 29) 10:33:50
    “The true test of a man, is what he does with power.” Plato
    Dave Lozinski replied 15 years, 1 month ago 2 Members · 1 Reply
  • Dave Lozinski
    August 22, 2011 at 3:33 am
    Does this error occur with any project? Or a specific project? Are you opening a file by double-clicking the .veg file? Or doing a “file | open” in Vegas? Or do you have Vegas set to automatically open the last project?
    What happens if you launch Vegas, create a new project, save it, and then try reopening it?
    https://www.davelozinski.com
    https://www.davelozinski.com/DemoReel/
