Activity Forums VEGAS Pro Vegas Pro 10 install problem
  • Vegas Pro 10 install problem
    Posted by Phil Byrd on February 16, 2012 at 5:12 pm
    I’m moving editing to a new i7 machine with 16gb memory running Windows 7 64bit operating system. I’ve installed Vegas Pro 10 (64 bit) and DVD Architect 12 (32 bit). When it is time to register the apps, I get a message advising that there is a problem. Following instructions on Sony’s help screen I enter machine number for an special authorization code and ultimately am told that I’ve entered an invalid serial number. But in each case, the numbers are correct. I’ve checked and double checked.
    Is there something I’ve missed in Sony’s instructions? Is there a secret phone number for support from Sony? I’ve never received a reply when I’ve sent e mail to Sony.
    But I really like my new machine!
    Adam Kacau replied 14 years, 6 months ago 4 Members · 5 Replies
  • Stephen Mann
    February 16, 2012 at 9:43 pm
    Make sure you aren’t entering a zero for the letter “o”, or vice-versa…
    The support number for Sony is no secret, but you should be calling customer service (not tech support) for activation or serial number problems.
    800.577.6642, 9:00 a.m. to 5:00 p.m. CST, Monday through Friday
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Adam Kacau
    February 17, 2012 at 5:15 pm
    hi. please help me. i’m new to sony vegas and to this forum. just now i was editing a video, i opened a window(not sure what it is called) like video media generator and then i moved it a bit and suddenly it became attached to the other group(also not sure how to say it). what i want is the window to be popped up like it usually does. kindly pls help. 🙁
  • Bob Peterson
    February 17, 2012 at 5:54 pm
    You should open a new topic to get the best response.
    Vegas allows you to drag things around, and tends to “attach” things to a new position easily. Simply click and drag it away from its new home and drop it where you want it.
  • Phil Byrd
    February 17, 2012 at 5:59 pm
    Hi all.
    Regarding my post that started this thread, I finally figured out how to get help on line from Sony. Problem had been too many installs, as I’d had some hard drive crashes and changed machines. Help from Sony was very prompt. Thanks for the help in finding the help.
    Phillip Byrd
    Brandenburg Productions, Inc.
    Montclair, NJ USA
  • Adam Kacau
    February 18, 2012 at 5:33 am
    thanks Mr. Bob Peterson. It worked. thanks a lot.
