Activity Forums VEGAS Pro Vegas Pro 10 32 or 64 bit version?
  • Vegas Pro 10 32 or 64 bit version?
    Posted by Joseph Dezordi on May 22, 2011 at 11:50 pm
    I have just installed Veg Pro 10, and was given option of 64 or 32 bit on the CD
    I suspect that some plugins will not install into the 64 bit version…
    is there any advantage to using the 64 bit version ? ( I have an i7 qadcore)
    Joseph D
    Mike Kujbida replied 15 years, 4 months ago 2 Members · 1 Reply
  • Mike Kujbida
    May 23, 2011 at 1:13 am
    The advantage to 64 bit is access to all your RAM instead of only 2 or 3 GB. of it.
    The standard recommendation is to install both versions as they will peacefully co-exist on your system.
    That way, if any of your plugins are 32 bit only, you can still use them.
