Activity › Forums › VEGAS Pro › Vegas pre-rendered files
  • Vegas pre-rendered files
    Posted by Larry Brewer on May 4, 2011 at 3:12 am
    Recently finished a 30 min infomercial. Some clips HD, some SD, some color corrected. When I add an 800 number and print to tape, Vegas must pre-render most of the 30 min production to print a widescreen standard def tape. This takes about 30 – 45 mins due to the different format scaling and the color correction.
    The problem I’m having is.. Vegas wants to re-render the entire 30 mins everytime I call up the project and change the phone number which only involves about 6 mins of the entire program.
    How can I save the pre-rendered files so that when I call up the timeline to print another tape it would only have to re-render the section that has actually changed?
    Actually, the pre-renderd files are saved in the pre-render folder, it’s just that they are no longer being used on the timeline. How can I import them to the timeline so that I don’t have to start all over every time?
    Thanks in advance for any help I can get.
    Larry Brewer
    Douglas Spotted eagle replied 15 years, 5 months ago 2 Members · 1 Reply
  • Douglas Spotted eagle
    May 4, 2011 at 4:26 am
    Render to new track will fix this for you.
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
