Vegas Poor video rendering quality
Posted by Yia Vang on April 10, 2010 at 10:31 amPlease help Sony Vegas Capture quality!! I have a sony Fx1000, I shot the videos in HDV 1080i 24p and I am using sony vegas pro 9c to capture my video into my pc. In the bottom window it shown as follow; 720×480 29.970i vial firewire DV. So my question for you is;
1. what is the best setting for editing these footage?
2. What is the best setting for rendering?
3. is this resolution affecting my video quality?I’m frustrated because I have tried many diferent setting and video turned out streched and poor quality. Please give me a headup. Thanks.
John Rofrano replied 16 years, 4 months ago 3 Members · 9 Replies -
John Rofrano
April 10, 2010 at 12:16 pmIn the bottom window it shown as follow; 720×480 29.970i vial firewire DV
It sounds like you have your camera in DV Downconvert mode and you are actually capturing DV even though you shot HDV. You need to read your camera’s manual and make sure that it is placed in HDV capture mode. Then use the HDV capture tool in Vegas. If your captured footage isn’t recognized as 1080i you’re doing something wrong.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Scott Francis
April 10, 2010 at 1:11 pmOn Sony’s in the menus it is call iLink conversion and it has HDV-DV. make sure that is not enabled and capture in HDV SDI in Vegas like John said. Good luck!
Scott Francis
Mind’s Eye Audio/Video Productions -
Yia Vang
April 11, 2010 at 3:59 amI must have changed some setting some where because every I click on the capture video icon it doesn’t give me a choice whether to capture my video in DV or HDV-SDI. Please show me where to change the capture video mode to give me the choice of either DV or HDV-SDI capture mode. I will need a lots of help. Thanks much for your quick respond.
John Rofrano
April 11, 2010 at 12:44 pmPlease show me where to change the capture video mode to give me the choice of either DV or HDV-SDI capture mode.
In Vegas Pro go into Options | Preferences | Video and uncheck “Use external video capture application”. That will cause the internal HDV capture to be called the next time you use File | Capture Video.
~jr
Yia Vang
April 11, 2010 at 5:33 pm? now it captured in HDV 1440x1080i,but my preview screen is blank and I cannot see what is beeing capture. The sound comes out, but no preview video on my preview screen. The capture clips is fine, I just can’t see it on the preview window. I do have an new HDTV monitor. Please help and thanks.
Yia Vang
April 12, 2010 at 1:56 amWhat about rendering setting to get the best HD DVD quality? Please show me how can I set up the setting to get the best video quality out of it. I noticed big video quality improvement since you guy show my how to capture it in HDV format other than DV. I’m editing it in 1440x1080i right now and need your help to help me to get the best video quality on to a DVD. Thank so much to your times and help.
John Rofrano
April 15, 2010 at 12:19 amThe best quality you can get from a DVD is unfortunately only DVD quality unless you want to burn a Blu-ray image to DVD media but these will not play in a DVD player, only a Blu-ray player. The best DVD compatible format is to render to MPEG2 using one of the DVD Architect templates and render your audio as Dolby Digital AC3.
~jr
John Rofrano
April 15, 2010 at 9:33 am
