Activity › Forums › VEGAS Pro › Vegas Pan/Crop Tool Plugin “LE” ???
  • Edward Troxel
    December 2, 2005 at 8:01 pm
    [Charles] “I can’t seem to spin an event either clockwise or cc, smoothly for about 5 revolutions”
    I just opened Pan/Crop, changed the “angle” to 1800, set another keyframe and set the “angle” to 0, and it seemed to work just fine.
    In Track Motion, I just did the same thing changing the “Rotation Angle” which also seemed to work fine.
    Edward Troxel
    JETDV Scripts
  • Gary Alan
    December 2, 2005 at 8:05 pm
    Charles,
    In Vegas 6 use the track header Motion and use 3D Source Alpha. Then enter in either the X,Y or Z Rotation value on the left menu for degress (positive or negative numbers determine direction of spin). One half spin is 180. Two full spins is 720 (360 + 360) and so on. Make sure you set two keyframes to make it happen. Five full spins is 1800 (5 x 360). You can also use different style keyframes (Linear, Fast, Slow, Smooth and Sharp).
    GG
  • Charles Avanti
    December 3, 2005 at 12:07 am
    Thanks guys! I should have known Vegas could have done it.
    I guess 3DLE is not needed after all.
    Charlie
Page 2 of 2
