Activity › Forums › VEGAS Pro › Vegas only partly renders with Transitions
  • Vegas only partly renders with Transitions
    Posted by Barry Purcell on July 30, 2019 at 4:46 pm
    Hi Guys
    I’m looking for some help I bought my pc about 2 years ago as I intended on going into video editing and it had what I wanted very well maintained a very fast processor as well as a copy of Vegas Pro11 installed . Just lately when I add certain transitions my project only partly renders but when disabled it renders perfect . I’m not sure is it a Win 7 32 bit issue my processor or Vegas itself. Maybe someone might offer me some suggestions as I can’t really finish any projects and I’m not too keen on leaving out transitions or rendering my projects in parts .
    Many thanks
    Barry
    Windows 7 Ultimate 32 Bit Operating System
    (Service Pack 1)
    Processor Intel (R) Core (TM0 i5 -2500K CPU @3.3GHz
    Installed Memory (RAM) 8.00gb (1.92 GB usable)
    Francois Pénzes replied 7 years, 1 month ago 2 Members · 5 Replies
  • Francois Pénzes
    July 31, 2019 at 12:40 pm
    Hi Barry
    Have you tried rendering with GPU acceleration OFF ?
    Also, some transitions (or combination of transitions/effects) can be very CPU/Memory intensive.
    Cheers !
    PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
    Cameras: Canon XF305 + Canon XH-A1
    Blackmagic HyperDeck Studio Mini
    Vegas Pro 16, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
  • Barry Purcell
    August 1, 2019 at 10:38 pm
    Hi Francois
    My Graphics card doesen’t support GPU acceleration I realise some transitions can be high on CPU usage but lately no matter which transition I use it won’t render. I’m wondering is my Graphics card and Win7 32 bit sufficient for running this prog?
    Thanks for your response
    Barry
  • Francois Pénzes
    August 2, 2019 at 1:18 am
    Hi Barry
    Can you post your machine specs (model #)in details please ? (Motherboard, CPU, GPU, RAM, etc…)
    Cheers !
  • Barry Purcell
    August 2, 2019 at 9:19 am
    Here you go Francois hope this is ok
    Regards
    Barry
    OS Name Microsoft Windows 7 Ultimate
    Version 6.1.7601 Service Pack 1 Build 7601
    Other OS Description Not Available
    OS Manufacturer Microsoft Corporation
    System Name BARRY-PC
    System Manufacturer To Be Filled By O.E.M.
    System Model To Be Filled By O.E.M.
    System Type X86-based PC
    Processor Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz, 3301 Mhz, 4 Core(s), 4 Logical Processor(s)
    BIOS Version/Date American Megatrends Inc. P1.20, 07/11/2011
    SMBIOS Version 2.7
    Windows Directory C:\Windows
    System Directory C:\Windows\system32
    Boot Device \Device\HarddiskVolume1
    Locale Ireland
    Hardware Abstraction Layer Version = “6.1.7601.24499”
    User Name BARRY-PC\BARRY
    Time Zone GMT Daylight Time
    Installed Physical Memory (RAM) 8.00 GB
    Total Physical Memory 1.92 GB
    Available Physical Memory 543 MB
    Total Virtual Memory 3.83 GB
    Available Virtual Memory 2.00 GB
    Page File Space 1.92 GB
    Page File C:\pagefile.sys
  • Francois Pénzes
    August 2, 2019 at 12:01 pm
    Hi Barry
    The reason I’m asking is that Vegas 11 was the last version that could run off a 32 bit system. 32 bit systems, like yours, can only use a theoretical maximum or 4 Gigs of RAM. All of that is fine and dandy but once your system is up and running (Idle) you would have something like 3.4 Gigs left. Once you start a program (i.e. Vegas) that amount drops again. When you get to rendering, there is not much of the minimum required to run you OS, all of your background operations and your Vegas tasks.
    Granted, your version of Windows has what they called Page Files (virtual memory). When your RAM becomes full, Windows moves some of the data from your RAM back to your hard drive. Back and forth. You can imagine how strenuous it can be on your system, especially when rendering. At some point, it just gives up.
    There are no 2 ways about it, video editing requires a powerful computer if you want to go beyond straight cut only editing. Treat yourself to a better system. Doing a search on Google will yield a ton of information about what to get or how to build a proper one according to your available budget.
    Cheers !
