Activity Forums VEGAS Pro vegas on mac quad
  • vegas on mac quad
    Posted by Matt Cohn on December 18, 2008 at 7:41 pm
    Hi
    is it possible to run vegas8 on a mac pro quad (=2 x quadcore 3.2ghz + 8gig ram) using bootcamp? i would need to run vista 64bit to use the 8gig ram ?
    does anyone do this? as i understand it, these macs are the only 8 cpu machines out, so are the fastest. But, i love vegas over fcp…
    If this will not work, what would be a good spec pc to get to run Vegas? I need to render at hd , probably 720i.
    thanks for any help
    Matt Black, Coldcut
    George Wingard replied 17 years, 9 months ago 3 Members · 3 Replies
  • Mike Kujbida
    December 18, 2008 at 8:51 pm
    I’ve read numerous posts on a bunch of Vegas forums where folks are doing this every day and are quite happy with it.
    If yo don’t want to invest in a Mac, build a PC based on the new Intel Core i7 chipset.
    Render times are reported to be as much as twice as fast as a quad core.
  • Matt Cohn
    December 19, 2008 at 1:46 pm
    Thank you, Mike. I’ll check it out.
  • George Wingard
    December 19, 2008 at 5:50 pm
    you could run it if you had a hackintosh…Intel supported chipset…ie xbx2(bad axe 2) motherboard. There are more…( https://forum.insanelymac.com/lofiversion/index.php/t60144.html ) the bleeding edge usually is a pain (I figure the i7 fits this category)
    Give Me More Silicon!
