Activity Forums VEGAS Pro Vegas not utilizing ram
  • Vegas not utilizing ram
    Posted by Jerry Waters on October 31, 2006 at 4:52 am
    I read that some of you running Windows 64 bit were allocating 2gb under preferences. My new machine is Tyan Thunder with 2 265 opterons (dual core) and 4gb ram. Vegas says that max ram is 1024 and will not accept more. The machine recognizes 4gb of ram on boot up. How can I allocate more ram?
    JerryW
    Terje A. bergesen replied 19 years, 10 months ago 2 Members · 3 Replies
  • Terje A. bergesen
    November 1, 2006 at 3:52 am
    Vegas will use as much RAM as it needs up to the limits imposed upon it by Windows. The memory setting for dynamic RAM pre-view is used for one specific feature of Vegas, namely dynamic RAM pre-view, not for Vegas as such. Do you have any particular reason for needing more than 1G of RAM for dynamic RAM pre-view?
    Note that under windows, the maximum memory available to any one application is 2G.
    Terje A. Bergesen
  • Jerry Waters
    November 1, 2006 at 4:37 am
    Yes, I’m doing some transitions with HDV Cineform intermediates (1440 X 1080) and 1gb is too limiting to some of them. If I can allocate 2gb and still have 2gb, why not?
    JerryW
  • Terje A. bergesen
    November 1, 2006 at 3:19 pm
    A 32 bit application in Windows can only allocate 2G of memory (Windows limitation). I assume the 1G max for pre-render comes from this. Since Vegas can never use more than 2G of RAM, setting aside some for it self, any codecs it will need to run etc, isn’t unreasonable.
    Terje A. Bergesen
