Activity Forums VEGAS Pro Vegas mp4 renders
  • Vegas mp4 renders
    Posted by Brian on September 19, 2010 at 6:20 pm
    I’ve been trying to render out to mp4 (both main concept and sony flavors) and get “No template available” messages in Vegas 6. Vegas 9 is on the same computer and renders to mp4 normally — I say normally because v.9 often crashes or gives inadequate RAM messages so if possible I’d rather use v.6.
    Fix?
    Brian replied 15 years, 12 months ago 2 Members · 4 Replies
  • John Rofrano
    September 19, 2010 at 11:20 pm
    Try re-installing Vegas 6 to re-establish the templates. They should be there for both MainConcept AVC and Sony AVC.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Brian
    September 23, 2010 at 10:16 am
    I just reinstalled Vegas 6d and have the same issue. It says “No existing templates support this media”. Mainconcept and Sony AVC.
    The custom tab is grayed out.
  • John Rofrano
    September 23, 2010 at 10:34 am
    I’m not sure what could be causing this. Perhaps it’s because you also have V9 installed? Are you using Windows XP? (which is the only OS that 6 supports). I have Vegas 6 installed alone on XP and the templates are there. Sorry I can’t be of more help.
    ~jr
  • Brian
    September 23, 2010 at 3:33 pm
    Hi John
    Yes I have v.9 installed but am using Vista 64.
    I’ve tried using Handbrake and it seems to work okay, but I’d sure like to render from Vegas.
