Activity Forums VEGAS Pro Vegas Movie Studio Platinum 11 functioning slow
  • Vegas Movie Studio Platinum 11 functioning slow
    Posted by Danielle Cholly on August 1, 2015 at 8:57 pm
    Hey there!
    I just purchased a new camera and am trying to use the clips I filmed in Vegas. But the program is functioning extremely slowly. Even just clicking between clips, it takes several seconds before the new clip shows up in the preview window. I have tried several different ‘fixes’ and nothing seems to be working. I have a feeling it has to do with the clips inputted, I have read something about ‘codecs’? (I am a self-taught editor and still learning) Any help or advice would be greatly appreciated!!
    My comp is a Toshiba Satellite S55-B
    ram: 12 GB
    Processor: Intel(R) Core(TM) i7-4510U CPU @ 2.00GHz 2.60 GHz
    Aaron Star replied 11 years ago 3 Members · 6 Replies
  • Danny Hays
    August 1, 2015 at 11:41 pm
    I think your new camera is making video files a type that Vegas has a hard time with. I bet your preview window settings are at best full. If they are, try setting it to preview auto and see if that makes a difference.
  • Danielle Cholly
    August 1, 2015 at 11:49 pm
    My preview settings are at Preview (auto). and I’ve played with those for way too long.
    Okay, so if it IS the files, what are optimum settings for them? I can convert them, but don’t know what to. Any resources out there?
  • Aaron Star
    August 1, 2015 at 11:55 pm
    I would post your speccy info on your systemm, and “media info”(the application) on your camera media you are trying to edit. This would help us help you better.
    I would try directly converting footage to xdcam.MXF or xdcam.mp4 and see if that plays back smoother for you.
  • Danny Hays
    August 2, 2015 at 1:01 am
    Yea, what Aaron said. I believe Vegas can do that for you. Or at least to some other lossless codec file.
  • Danielle Cholly
    August 3, 2015 at 12:43 am
    General
    Complete name : C:\Users\Danielle\Videos\Johnson Farewell\20150730203031.MTS
    Format : BDAV
    Format/Info : Blu-ray Video
    File size : 188 MiB
    Duration : 1mn 36s
    Overall bit rate : 16.4 Mbps
    Maximum Overall bit rate : 18.0 Mbps
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 2 frames
    Format settings, GOP : M=1, N=30
    Codec ID : 27
    Duration : 1mn 36s
    Bit rate mode : Variable
    Bit rate : 15.5 Mbps
    Maximum bit rate : 16.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 29.970 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.250
    Stream size : 178 MiB (94%)
    Audio
    Menu ID : 1 (0x1)
    Format : AC-3
    Format/Info : Audio Coding 3
    Mode extension : CM (complete main)
    Codec ID : 129
    Duration : 1mn 36s
    Bit rate mode : Constant
    Bit rate : 256 Kbps
    Channel(s) : 2 channels
    Channel positions : Front: L R
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Compression mode : Lossy
    Delay relative to video : -67ms
    Stream size : 2.93 MiB (2%)
    Text
    Menu ID : 1 (0x1)
    Format : PGS
    Codec ID : 144
    Duration : 1mn 35s
  • Aaron Star
    August 3, 2015 at 8:19 pm
    I know it may seem like a hassle, but converting all of your .MTS to XDCAM, then editing the xdcam will be a much better experience.
    I believe the .MTS format is not that well optimized in Vegas, when compared to XDCAM. Also in the past I had issue with an old sound card editing MTS and AC3. Converting to XDCAM changes the audio from Dolby owned MP3 to uncompressed audio. Uncompressed PCM audio is more stable with most sound cards. I think editing MTS, you have two simultaneous decompressions going, then Vegas has to mux the result back to together on the fly. It is my believe this process has bugs in MS 11.
    Have you tried the free trial of the latest release, to see if that is any better?
