Activity Forums VEGAS Pro Vegas Lag
  • Vegas Lag
    Posted by Brian Bilgen on December 9, 2007 at 9:49 pm
    Hello, thanks in advance to all who help.
    Well I bought a sony dvd camcorder under the assumption i could drop discs in and edit with microsoft movie maker. I have realized it isn’t that easy due to the .vod files.
    My problem is I downloaded the free trial of Vegas Platinum Sony has marketed thinking things would be great now. My new problem is the footage lags pretty bad and is choppy. I have shut down everything running except the Vegas software that I could but I still have the same problem.
    My computer is a 32bit HP dual core 5000 with 2gb of ram and an additional 512 on the video card. (I put in a new video card). Can anyone help me understand what I might be doing wrong? Do I need more memory? AM I missing something. I did make a movie on the microsoft movie maker that came with the computer and the lag was no where close to what the Vegas is having.
    thanks again, I hope there is a cheap, simple, solution.
    Rick Mac replied 18 years, 9 months ago 6 Members · 19 Replies
  • 19 Replies
  • Jerry Waters
    December 9, 2007 at 11:18 pm
    What are your preview settings? With HD you usually have to run Preview – Auto (or a quarter) to get a decent running preview. In Full – Best it will lag. Sometimes you have to go Tools – Build dynamic ram to see you are in sync. In Vegas it is all about the processor speed. It doesn’t use the video card.
  • Rick Mac
    December 10, 2007 at 1:04 am
    [Brian Bilgen] “under the assumption i could drop discs in and edit”
    I hope that you transfered the footage from your camcoder
    to your hard drive. If you are trying to edit directly from your DVD that would explain the lag. Your DVD cannot move the data fast enough..
    Regards, Rick.
    Rick Mac
    Director of Audio Production
    TCT Network – Directv 377
  • Brian Bilgen
    December 10, 2007 at 1:23 am
    Thanks, I tried preview under each setting and I still continue to have problems with it being “Choppy”. It seems like it gets worse as more footage is added to the timeline.
    So you know there is a total of 3 minutes and 44 seconds of footage I have on the timeline so it is nothing ridiculous.
    Would I not have this problem if I were using the previous version of Vegas that does not support HD capability? Since my camera is DVD based I am not editing HD footage anyways, I guess what I am getting at is this software overkill for me and my computer?
    I also tried to adjust the “dynamic ram” under tools but I haven’t had much luck with this either.
    Thanks.
  • Brian Bilgen
    December 10, 2007 at 1:29 am
    thanks Rick,
    Yes I put it on my hard drive and imported in to Vegas. It was one file at just over 3 minutes. I have tried other files from different discs and run into the same problem.
    Thanks though, one more check I can cross off.
  • Rick Mac
    December 10, 2007 at 3:22 am
    Here is another one to check. Forgive me if it sounds
    to basic.
    You should be putting your video media on a seperate drive than your operating system. Your preview settings should be
    “Preview Auto”.
    By the way what type of file is this? HDV MPEG? What Codec?
    Regards, Rick.
    Rick Mac
  • Brian Bilgen
    December 10, 2007 at 12:39 pm
    Hey Rick, No offense taken I know somethings are easily overlooked, or done incorrectly, so I definitely don’t mind checking the basics.
    First the files I am trying to import into Vegas are .vod files from the DVD I originally recorded onto.
    As far as putting media on a seperate drive than the operating system, I am not sure I understand or are 100% clear on what you mean. I have my OS, (Windows Vista) on the C: drive. I copied my video from the camcorder DVD into a folder named “Video” on my C: drive.
    Are you saying that I need a seperate hard drive that in theory has nothing but video footage stored on it?
  • Allen Zagel
    December 10, 2007 at 1:05 pm
    You really don’t ever want to put video files on your C drive. That’s your system drive.
    I got all my software installed on my C drive, maybe a few photos, but I have 3 internal hard drive’s a well as 2 external. My external hard drives (firewire connection) are for storing my unused or finished video files. I don’t even like editing files from an external HD.
    One of my other internal drives have my video folders. Putting video files on your system drive can be causing your problems.
    Also you mentioned VOD files. Don’t you mean VOB?
    Allen
  • Brian Bilgen
    December 10, 2007 at 1:43 pm
    Hmmm…..
    I have a hard drive from the computer I just uprgraded from I could try and install onto my new computer.
    Would there be any minimum specs that the secondary hard drive would need to meet?
  • Brian Bilgen
    December 10, 2007 at 1:45 pm
    and sorry yes I mean .vob files
  • Mike Kujbida
    December 10, 2007 at 1:51 pm
    Typical recommendations are a 7200 rpm drive that is set to (at least) DMA mode, preferably UDMA.
    BTW, due to their very nature, I’ve always found files from a miniDVD camcorder to be the absolute worst to edit with and have learned to put up with the slow response time.
