Vegas Lacks
Posted by Rosh Kadri on April 23, 2010 at 11:43 amFolder tracks and the second feature stopping me for doing sound post in it is the ability to drag the volume handle upwards on a track. Im not talking about normalizing or adding a volume plugin which is a blind way of doing this, i mean like cubase in which you can drage the handle upwards and the waveform updates. Kind of sad not to see this implemented. Any work arounds that are similar? without soundforge
Rosh Kadri replied 16 years, 4 months ago 4 Members · 7 Replies -
John Rofrano
April 23, 2010 at 1:31 pmi mean like cubase…
Cubase is Steinberg’s DAW. ACID Pro is Sony’s DAW. ACID has folder tracks already. I too would love to see folders in Vegas but also for Video tracks as well.
You should look at ACID Pro and see what’s missing for you, then ask Sony to add those features to ACID. Vegas has primarily been focused on Video these days although it’s still an exceptional audio app.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Rich Stahle
April 23, 2010 at 2:59 pmpersonally – i prefer to take my audio and edit a master file outside of vegas ie sonar, cubase, etc render your master audio file and pull into vegas.
vegas is only so-so for audio imo better off processing it in your favorite audio application
Damaged FX
Underground Video Television
My Director Website -
Scott Francis
April 23, 2010 at 7:00 pmI mix everything in Cubase and then do “stems” (basically subgroups) and render those to use in Vegas. I do a little processing in vegas but nothing major….have had good results with this!
Scott Francis
Mind’s Eye Audio/Video Productions -
Rosh Kadri
April 26, 2010 at 9:55 pmits really too bad these features are not implemented. I think if vegas had folder tracks, the ability to pull up the volume envelopes past 0 and other DAW features, rarely would anyone need to roundtrip. I wonder if sony has some kind of deal with steinberg not to do this because many of us asked for these features several versions ago.
Thanks for your replies.
Scott Francis
April 27, 2010 at 2:47 amPulling audio up “past zero” is not always a good thing and headroom can be found by lowering all your other tracks, a little more work BUT keeps you from cliping. I have found that Vegas IS a reasonable DAW, however, it is what it is. I have done a fair amount of “remixing” of my stems in Vegas with very good results….plugins are the key, Waves, Izotope, and Antares have all given me good results in Vegas…plus I LOVE being able to output to Sound Forge to do more detailed editing, much nicer than the editor in Cubase IMO…good luck!!
Scott Francis
John Rofrano
April 27, 2010 at 10:44 amthe ability to pull up the volume envelopes past 0
I’m not sure what you mean by this. Vegas volume envelopes go up to +6dB past 0. It just doesn’t change the view of the waveform. I think you may be talking about the Gain control. This is NOT a volume envelope. The volume envelopes start at 0dB and go up to +6dB and down to infinity.
~jr
Rosh Kadri
April 28, 2010 at 7:08 amYes scott, my wording may have been confusing. Its the ability to turn up the gain while seeing the waveform update. As you know, this may be helpful in matching volumes across clips without normalizing.
I usually work with 2 or three dialogue tracks, 2 music, several sound fx tracks also. This can become clutter very fast, i would love to see the folder tracks implemented, i also love the look of the mixer in cubase and wished vegas had it. Of course its not just about the looks, i just find it easier.
