Activity Forums VEGAS Pro Vegas Keyframe Interpolation
  • Vegas Keyframe Interpolation
    Posted by Connor Cottrell on December 25, 2022 at 8:16 pm
    When you’re adjusting the interpolation of two keyframes, with one being the beginning of an effect animation, and the other being stretched to the end of the clip as the end of the effect animation, does the setting you use for that last keyframe actually have an effect on the interpolation of the effect?
    Like, say I have two effect animation keyframes, with the first one being set to “slow” and the second one being set to “fast”. Will the effect animation go from slow to fast in its interpolation, if the second keyframe is at the end of the clip, or does the interpolation setting only affect what goes after that keyframe?
    I’m worried I’ve been laboring under the false assumption that progress between two keyframes with different settings is automatically phased from the first one to the next, rather than the keyframe setting only applying to what goes after that keyframe.
    Aivis Zons replied 3 years, 8 months ago 2 Members · 3 Replies
  • Aivis Zons
    December 26, 2022 at 10:48 pm
    By default no, the interpolation of the 2nd keyframe does not affect the values before it.
    When you have only 2 keyframes only the setting of the first one matters.
    If these keyframes are for an Effect you can switch from Lanes to Curves (see image). This will give you the best visualization for interpolation. Plus if you change the interpolation to “Bezier Curve” you will have max control over the curve.
  • Connor Cottrell
    December 27, 2022 at 7:00 pm
    Thanks for the reply! Hearing it from someone else is a good confirmation, since the way I was doing it was something I was told years ago and never 100% made sense.
    I’ve engaged the Curves view like you mentioned, but what’s this Bezier Curve you described? The only mention of that I can seem to find on my program is included in a screenshot below.
  • Aivis Zons
    December 27, 2022 at 10:13 pm
    “Bézier curve (locked tangents)” or “Bézier curve (split tangents)” – found at the bottom of the list when you try to change interpolation. Set the first keyframe to bezier and you’ll have those handles to edit the curve manually as seen in my original image.
    Those handles are only seen in the Curves tab.
