Activity › Forums › VEGAS Pro › Vegas is Crashing with too many 5D Mark II files??
  • Vegas is Crashing with too many 5D Mark II files??
    Posted by Dale Smith on March 11, 2009 at 3:38 am
    When I get to many files/clip in my video it crashes and gives me this error report
    Vegas Movie Studio Platinum 9.0 TRIAL
    Version 9.0b (Build 92)
    Exception 0xC0000005 (access violation) READ:0x0 IP:0x0
    In Module ‘VegasMovieStudioPE90.exe’ at Address 0x0 + 0x0
    Thread: ProgMan ID=0x1190 Stack=0x54CF000-0x54D0000
    Registers:
    EAX=00aeefb8 CS=0023 EIP=00000000 EFLGS=00010206
    EBX=039ab0d8 SS=002b ESP=054cf9e4 EBP=8007000e
    ECX=051a3fd8 DS=002b ESI=051a3cb0 FS=0053
    EDX=00000000 ES=002b EDI=051a3d44 GS=002b
    Bytes at CS:EIP:
    00000000: .. .. .. .. .. .. .. .. ……..
    00000008: .. .. .. .. .. .. .. .. ……..
    Stack Dump:
    054CF9E4: 01B9B69E 01940000 + 25B69E (vegasmoviestudiope90k.dll)
    054CF9E8: 051A3FD8 050F0000 + B3FD8
    054CF9EC: 00000000
    054CF9F0: 00AEEFB8 00400000 + 6EEFB8 (VegasMovieStudioPE90.exe)
    054CF9F4: 00000000
    054CF9F8: 00000000
    054CF9FC: 00000000
    054CFA00: 00000000
    054CFA04: 00000000
    054CFA08: 051A3CB0 050F0000 + B3CB0
    054CFA0C: 0C23EF78 0BF50000 + 2EEF78
    054CFA10: 00000002
    054CFA14: 8000FFFF
    054CFA18: 00742E91 00400000 + 342E91 (VegasMovieStudioPE90.exe)
    054CFA1C: 051A3CB0 050F0000 + B3CB0
    054CFA20: 0067EDE0 00400000 + 27EDE0 (VegasMovieStudioPE90.exe)
    > 054CFA28: 00AEEFB8 00400000 + 6EEFB8 (VegasMovieStudioPE90.exe)
    054CFA2C: 00000001
    054CFA30: 0C23EF78 0BF50000 + 2EEF78
    054CFA34: 0515F4B0 050F0000 + 6F4B0
    054CFA38: 00000000
    > 054CFA3C: 00743276 00400000 + 343276 (VegasMovieStudioPE90.exe)
    054CFFF0: 00000000
    054CFFF4: 005282F0 00400000 + 1282F0 (VegasMovieStudioPE90.exe)
    054CFFF8: 00AF3D58 00400000 + 6F3D58 (VegasMovieStudioPE90.exe)
    054CFFFC: 00000000
    where can I find a solution?
    Dale Smith replied 17 years, 6 months ago 3 Members · 3 Replies
  • John Rofrano
    March 11, 2009 at 2:42 pm
    What format does the 5D Mark II produce? Perhaps you need to transcode them into something Vegas Movie Studio can edit easier. I would see if something like MPEG Streamclip can convert them for you.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • John Adler
    March 11, 2009 at 5:51 pm
    Hi Dale,
    The 5dmk2 files are h.264 and Vegas can read them but it struggles with them. I convert them inside Vegas to MainConcept MPEG-2 with the same attributes (1920×1080 30fps progressive). Vegas handles the MPEG-2 files really well and they’re easy to edit.
    To make the conversion easier, I use a batch region-naming script and a batch render script. I can start this going with a lot of files and it’s done overnight, with the new files having the same name as the original files. You may have to limit the number of h.264 files you put on the timeline at one time if Vegas crashes from the sheer quantity (although I’ve never had a problem when all I’m doing is a straight conversion/render).
    The resulting files look good and can be burned directly to Blueray.
    John
  • Dale Smith
    March 14, 2009 at 4:19 am
    I end up buying Neo Scene from Cineform for 99 dollars and end up working in the AVI format…
    This has fixed the problem, the video generated by the Mark II are amazing… I finally have a editing solution…
    Thanks for your advice
