Activity Forums VEGAS Pro Vegas HELP
  • Vegas HELP
    Posted by Carlos R. dueñas on December 21, 2009 at 5:24 pm
    Thanks in advance for helping me on this..
    I have an Asus Notebook, core2duo,and i`m a vegas user for more than a year, i have been using my precious Vegas8.
    I had some issues with viruses, and i had to reformat mi PC. When i try to reinstall Vegas it stop on the very first screen and block´s the PC (after registering, its the start screen). Even the task manager cannot stop the process with the blocked Vegas. And the same its happening to Premier CS4 that a friend just lend me to check if it was Vegas itself. Its not opening and freezes on “Initializing external monitoring”.. Help
    (i have Vista,SP2)
    Paul Goelz replied 16 years, 4 months ago 4 Members · 5 Replies
  • Kristofar Rieleef
    December 21, 2009 at 5:39 pm
    Try installing as administrator. Right click & run as administrator on the drop down box.
  • Carlos R. dueñas
    December 21, 2009 at 5:49 pm
    Kris, thanks for the response, but allready done (administrator thing) i believe its the computer and something about “external monitoring”, not the software.. 🙁
  • Norman Willis
    December 22, 2009 at 2:29 am
    Hi Carlos.
    I am assuming you did a C:\format, and wiped the drive completely clean, so as to be sure to wipe the virus completely out.
    This may be a long shot, but have you checked the disk’s integrity?I.e., can you try running Checkdisk?
    I hope that helps.
  • Carlos R. dueñas
    December 22, 2009 at 5:01 pm
    Thanks a lot Norman, i will try that right now.. tell you later if it works..
  • Paul Goelz
    May 26, 2010 at 12:19 pm
    Out of curiosity, was this ever resolved? And if so, how?
    I have intermittent freezes while “initializing external monitoring” in 9.0d and 9.0e during program startup. They seem to only happen if the program has been closed and then re-opened, or more often when I open a second instance. The program does eventually finish initializing but it can take several minutes.
    I have a second monitor I use as an external monitor and I also have a firewire device but it does not provide output. Maybe Vegas gets confused and tries to initialize my F/W device for output? I haven’t tried pulling the plug when Vegas freezes.
    Paul
    Paul Goelz
    Rochester Hills, MI USA
    paul at pgoelz dot com
