Activity Forums VEGAS Pro Vegas freezes when I try to render
  • Vegas freezes when I try to render
    Posted by Tyler Kemp on April 5, 2013 at 6:45 am
    I just got a new computer and rendered a video with it perfectly. I then turned on the GPU acceleration. It froze on initializing that for a while but eventually started.
    The display window and all clips in the timeline were now blank instead of showing a preview.
    I turned GPU acceleration off, but since then when I go to render a video the display window turns black and Vegas will “render” infinitely without doing anything, and if I try to cancel the render it freezes and has to be shut down through the control panel.
    Any ideas?
    Tyler Kemp replied 13 years, 5 months ago 3 Members · 3 Replies
  • Mike Kujbida
    April 5, 2013 at 9:50 am
    Try a reset of Vegas first. Hold Ctrl + Shift while starting Vegas. That will reset all preferences and delete all cached data prior to loading the program. If that doesn’t work, then reinstall it.
  • Steve Rhoden
    April 5, 2013 at 11:51 am
    As Mike said, Resetting Vegas should do the trick.
    I assume this is the latest version of Vegas 12?
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-832-4956
  • Tyler Kemp
    April 5, 2013 at 4:43 pm
    I tried this and reset to defaults. Vegas works flawlessly until I try to render then the display screen goes black and the time to render continually rises with no frames being rendered.
