vegas file export into final cut pro
Posted by M. oliver Watson on February 5, 2007 at 5:41 pmHow do I export a vegas file so I can import it into final cut pro? Thanks –doinmabest
Edward Troxel replied 19 years, 7 months ago 2 Members · 3 Replies -
M. oliver Watson
February 6, 2007 at 2:22 amThanks! Now, how do I get that file onto a mac so I can import it. The file is over a gig, so I can’t use a thumb drive and an external hard drive needs to be formatted for either a mac or a PC, which, in either case would present a problem of getting it off of one and onto the other. I’m curious to see if it’s even possible. Thanks! — doinmabest
Edward Troxel
February 6, 2007 at 3:06 pm[doinmabest] “The file is over a gig, so I can’t use a thumb drive”
Why not? I’m using a 4Gig thumb drive.
[doinmabest] “and an external hard drive needs to be formatted for either a mac or a PC”
FAT32 will work on both the PC and Mac (with a 4Gig file size limit).
Then, of course, there’s always the possibility of transferring over a network.
