Activity Forums VEGAS Pro Vegas Error When Rendering mpeg-2 custom resolution
  • Vegas Error When Rendering mpeg-2 custom resolution
    Posted by Michael Menefee on November 2, 2009 at 3:01 pm
    Good day, and thaks in advance for any help you can lend here.
    I have a project for a client that needs to be 1360×768 for some monitors they use. I used After Effects to create the video but it is limited on mpeg-2 settings and does not allow custom resolutions. So, I use Vegas to render the final file in the correct package, etc.
    But when I go to render with Vegas using mpeg-2 at 1360×768, I get an error.
    To my knowledge, in the 5+ years I’ve used Vegas, I have never had this issue before. I have always been able to render out in any resolution I chose.
    Any idea on why this is happening?
    Using Windows 7 (RC) and Vegas 8.0b
    John Rofrano replied 16 years, 10 months ago 2 Members · 1 Reply
  • John Rofrano
    November 2, 2009 at 8:50 pm
    It depends on the codec… MPEG2 will not allow this odd resolution. You must conform to one of the MPEG2 standard resolutions. HDV 1280×720 is as close as you can get with MPEG2.
    You might want to use MPEG4 instead.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
