Activity Forums Adobe After Effects Vegas Effect – backwards?
  • Vegas Effect – backwards?
    Posted by Nate Hanson on August 14, 2009 at 10:24 pm
    I’m using the vegas effect on an open path. I have an expression controlling the “rotation” property. The expression uses time as a base value:
    time * x, where x is a number between 250 and 1000.
    Sometimes when I ram preview, the vegas effect runs backwards (following the path from the end to the start). I tried multiplying my expression by -1, and that worked for a while. Then, some of the layers started working backwards again.
    What am I missing here? Obviously I could just animate each layer by hand, but I’m trying to avoid that. Also, I have trouble putting a problem down until I understand it. Any ideas?
    Nate Hanson
    Pilothouse Films
    Todd Kopriva replied 17 years, 1 month ago 3 Members · 3 Replies
  • Filip Vandueren
    August 14, 2009 at 11:57 pm
    Is it perhaps a case of the wagonwheel spinning backwards ?
    https://en.wikipedia.org/wiki/Wagon-wheel_effect
  • Nate Hanson
    August 15, 2009 at 12:11 am
    Wagon-wheel effect: that was my third or fourth guess…but I slowed it way down and the problem persists. And it will change directions (occasionally) on a new ram preview, even when I haven’t modified any setting remotely related to the vegas effect.
    Maybe the adaptive resolution setting is guessing wrong from frame to frame? Maybe it has to do with random seeding? I unchecked the Random phase box. I’m stumped.
    Nate Hanson
    Pilothouse Films
  • Todd Kopriva
    August 15, 2009 at 1:55 am
    I think that Filip is on to something here.
    Setting a rotation value to 1000*time means that you’re rotating by a blazing speed of nearly 3 whole revolutions (1080 degrees) each second.
    The motion that you’re seeing (no matter what motion you’re seeing) is certainly an artifact of the temporal sampling of this wicked-fast stream of “lights”.
    I think that you’ll get much more sensible results if you set rotation to some much smaller multiple of time. Then you won’t be playing a guessing game or doing some complex math involving modulus operators.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
