vegas effect
Posted by John Culleton on January 19, 2012 at 12:49 pmi need to re create this… https://www.youtube.com/watch?v=VeBFoPXmkLE
are there any plug in Vegas effects that will do it?
it’s just the transition effect i’m after not the green screen
John Culleton replied 14 years, 7 months ago 2 Members · 8 Replies -
James Houghtaling
January 24, 2012 at 5:06 amYou could probably do this with a couple of tracks of each guy and a third track with the sparkle effect. Play with some of the Brightness/Contrast filter until you get a washed out silhouette, then add a filter to colorize it. Fade that in then cross fade it to the normal version of the guy. Start with both identical clips one on top of each other, color one on top, then split (“S” key) the top track where you want the normal one to come in so they stay in sync. Your spakle effect goes on top… you’re on your own on that..it looks like a particle effect. try some of the free smoke samples and colorize them to match – video co-pilot might have a couple free ones or you could make your own. I don’t think vegas has a media generator that would get you there.
My Hardware:
Core i7 2.67GHz; Nvidia GTX580, 12 gig RAM.My Software:
Vegas Pro V11 with Boris Continuum Complete 7, VASST Ultimate S; Bluff Titler; AE5; PhotoPaint and other stuff. -
John Culleton
January 24, 2012 at 10:03 amit’s the particle effect i’m after James, i cant seem to find anything in Vegas like that?
James Houghtaling
January 24, 2012 at 6:11 pmVegas does not have a particle generator. That’s why I suggested a stock media clip (like smoke) that you could colorize or modify with filters to match the look you’re after.
You might also try playing with lens flares or rays filters.
My Hardware:
James Houghtaling
January 24, 2012 at 7:42 pmHere’s a quick and dirty experiment using the approach I mentioned above where I duplicate the keyed talent track and applied brightness/contrast filter with glow and a flare to simulate an effect similar to, but not nearly as nice, as the one you’re after. But it may give you some ideas:
https://vimeo.com/35587280 password is “test”The veg and sample files are in this zip:
https://jameshoughtaling.com/TEMP/EffectTest.zip—————
My Hardware:
John Culleton
January 24, 2012 at 7:59 pmthank you James, that looks like it will do the job, just downloaded the veg file.
James Houghtaling
January 25, 2012 at 12:54 amYes, it is 64bit. I didn’t know the veg files were different. It’s also V11 which may be the problem. What version of Vegas are you running?
Not sure if this image helps (click to enlarge). There’s a blue and a white glow. The lens flare is added as a project FX.
My Hardware:
John Culleton
January 25, 2012 at 10:17 amim still V10 32bit, but no probs i can work it from the graphic, many thx.
John
